Home > Maintenance & Mods (L405) > RR SDV8 P0107 fault |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Sounds like a split inlet manifold or hose. Kev
22nd Jan 2021 7:23pm |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 |
Hi thanks for your reply.
22nd Jan 2021 11:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Pop the engine cover off and have a look at the 4 small rubber inlet pipes for splits |
23rd Jan 2021 1:34am |
Thanks again both !
23rd Jan 2021 7:58am |
Just to update, it’s my map sensor at fault.
29th Jan 2021 8:23pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2491 |
The running-on after switch off is often noticed with both the TDV8/SDV8 4.4 and the TDV6/SDV6 3.0 engines when in restricted performance mode. |
30th Jan 2021 8:57am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1096 |
MAP or MAF letters not necessarily in the right order |
30th Jan 2021 11:13am |
MAP sensor. £92 from Land Rover. Things tiny too, you wouldn’t think it could disable a RR ! |
30th Jan 2021 4:38pm |
GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 16 |
Just to help others in future. I too have just had a Restricted Performance message on a SDV8. Fault code was P0107-00 MAP sensor. Changed MAP sensor and all good to go. $500+ part in Australia from the dealers but only took 5 minutes to install. |
31st Mar 2024 7:58am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
They soon get clogged up, but are usually fine if given a good clean and put back in.
31st Mar 2024 8:09am |
Tried to clean it first, but that didn’t work this time |
31st Mar 2024 11:39am |
