Home > Maintenance & Mods (L405) > RR SDV8 P0107 fault
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
RR SDV8 P0107 fault
Hi all,
Had the dreaded “restricted performance” red light come on a couple of time recently.
Managed to get home then the next day normal again ?
Had it plugged in and the fault P0107 “ absolute pressure in intake manifold - barometric pressure - input low” was logged.
Had no other running issues, but have heard a strange noise coming from the vent on the drivers side under bonnet on the top of the wing that’s feeds the air filter housing ?
If I Rev it, it sucks like mad and makes a strange noise.
I’ve noted the fault only appears under hard driving. General tootling about there’s no issue ?
It’s in at a garage now but hoped the experience on here to help me point out some things to check.
Thanks in advance all !
Post #580779 22nd Jan 2021 6:34pm
knwatkins
Sounds like a split inlet manifold or hose. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #580783 22nd Jan 2021 8:23pm
Sester
Hi thanks for your reply.
Would I not hear a suction nose from the manifold if it were split ?
I’ll get the mechanic to check that over but was thinking more of a sensor ?
Is there a tell tale sign to look for with a split manifold ?
Thanks
Post #580820 23rd Jan 2021 12:31am
Pop the engine cover off and have a look at the 4 small rubber inlet pipes for splits Thumbs Up
Post #580823 23rd Jan 2021 2:34am
Sester
Thanks again both !
I’ve passed this on to my mechanic to investigate.
I’ll let you know of any findings 🤦‍♂️
One thing I did forget to mention but don’t know if it’s normal, when the restricted warning is on, if I turn engine off, it continues to run for 3/4 seconds before turning off ???
If anyone has any other suggestions I’m more than happy to hear them !
Thank you again 👍
Post #580825 23rd Jan 2021 8:58am
Sester
Just to update, it’s my map sensor at fault.
Thanks for your help guys
Post #581675 29th Jan 2021 9:23pm
GraemeS
Australia
The running-on after switch off is often noticed with both the TDV8/SDV8 4.4 and the TDV6/SDV6 3.0 engines when in restricted performance mode.
Post #581706 30th Jan 2021 9:57am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
MAP or MAF letters not necessarily in the right order
Post #581728 30th Jan 2021 12:13pm
Sester
MAP sensor. £92 from Land Rover. Things tiny too, you wouldn’t think it could disable a RR !
Post #581779 30th Jan 2021 5:38pm
GaryR
Australia 2014 Range Rover Vogue SDV8 Fuji White
Just to help others in future. I too have just had a Restricted Performance message on a SDV8. Fault code was P0107-00 MAP sensor. Changed MAP sensor and all good to go. $500+ part in Australia from the dealers but only took 5 minutes to install.
Post #689477 31st Mar 2024 8:58am
Baltic Blue
They soon get clogged up, but are usually fine if given a good clean and put back in.
Post #689480 31st Mar 2024 9:09am
GaryR
Tried to clean it first, but that didn’t work this time
Post #689497 31st Mar 2024 12:39pm
