Home > My Range Rover > Back with another Supercharged |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Well done David, a massive task and all finished to a high standard.
7th Sep 2022 3:37pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
to be fair David that is not too bad for a fully sorted car that you intend to enjoy.
7th Sep 2022 4:13pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
Great news, well deserved after all that work.
7th Sep 2022 4:40pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
It must be said following these updates that I have the upmost respect and admiration for you and your work.
7th Sep 2022 6:00pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
The RR is back
7th Sep 2022 6:20pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 600 |
Well done one sorted RRnow enjoy |
7th Sep 2022 6:52pm |
That’s the RR now done 250 miles since it passed it’s MOT and other then the fuel gauge moving at an alarming rate it’s been faultless
12th Sep 2022 1:09pm |
David, i had this on my 2012 TDV8 and it turned out to be the center prop bearing was shot all the rubber around the bearing had perished or was perishing. now with all the work you have done i cannot remember if you have inspected this part or not. Bearings are cheap enough to purchase and with your workshop a straight forward job too. I also changed out the UJ while i was at it. 2012 Vogue 4.4 TDV8 - Current
12th Sep 2022 3:01pm |
Thanks Jayk.
12th Sep 2022 6:09pm |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 391 |
Great to hear David - I'm getting 18.2 (Don't forget the .2) according to computer. That was on an hour run up the A1 to Peterborough for the Land Rover show at a steady 70mph. I can live with that - I would imagine the roads are more twisting and hilly up there so your mpg takes a hammering Gavin
12th Sep 2022 6:38pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Smiles per gallon mate that's all I can say |
12th Sep 2022 10:02pm |
Absolutely Bean!
13th Sep 2022 2:28pm |
Have only done around 300 miles in the RR at the moment.
25th Sep 2022 6:16pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
On mine it was the front lower suspension bushes. |
25th Sep 2022 6:20pm |
