Home > My Range Rover > Back with another Supercharged
Page 26 of 58 <123 ... 252627 ... 565758>
Great to see them in action David! Thumbs Up
Cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #629679 25th Apr 2022 1:44pm
dhallworth
@Superspoons - I've probably gone way OTT with mine due to the fact I've had the ramp. I've probably done a fair amount of work that it didn't actually need. Not like me to go charging straight in though apparently... Laughing
Thanks Alan Smile Glad to have finally got them fitted!
Just a few more little jobs to do and this car will finally be where I want it to be I reckon!
Post #629682 25th Apr 2022 1:56pm
dhallworth
Following on from my PCV thread here: https://www.fullfatrr.com/forum/topic63251.html
I started to strip down to get to the vacuum leak I discovered with the smoke tester last night.
The Supercharger is now removed.
I then decided to spend a bit of time on the charger this evening as I’ve got the bearing kit arriving either tomorrow or Saturday from Powerhouse.
It’s about time I had some good luck… there’s barely any wear on the rotors and there’s no float in the rotor pack bearings so it looks like it can be rebuilt without much fuss.
Just need to clean them gently to remove my oily finger marks.
With a bit of luck the bearings from Powerhouse will be here tomorrow Smile
Post #630044 28th Apr 2022 10:23pm
dhallworth
Tonight saw a bit more time on the lathe to make an adapter for the smoke tester Smile
That was then screwed into a scrap bit of steel that I’d drilled bolt holes in the right place on.
I then put some foam on the back of that to help it seal and bolted it to the charge cooler.
And connected the pipe from the smoke machine to it.
Initial pressure testing at 10PSI didn’t reveal anything. I then upped the pressure to 20PSI and there was a tiny bit of smoke visible from underneath the charge cooler on the OS bank of cylinders.
I removed the charge coolers as I’ve got new gaskets arriving tomorrow. If I could get my hands on the little 🤬 who had been in there before me I’d willingly do time for killing him. Instead of replacing the gaskets, everything had silicon on both sides of it. It’s taken me 2 hours with a Stanley knife blade removing all the mess.
Anyway, once the charge coolers were off I decided I’d do the valve cover gaskets as they were leaking oil down both sides of the engine. If you do it when the charge coolers are in place you need to depressurise the air conditioning. Thankfully, doing it this way you don’t.
First job for tomorrow after a trip to the dealer to collect parts is to spin it over on the crank pulley and check the valve clearances. That’ll give me a good idea on how badly the valve seats have suffered on LPG as when the seats are knackered there’s no clearance.
I’m hoping that they’re OK as I don’t want to go any further then this at the moment despite having a brand new set of cylinder heads on the shelf in the workshop.
Post #630132 29th Apr 2022 11:55pm
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Hi David
Have read your entire thread recently. - great work.
Yours is one of the opinions I hope to get on my potential candidate (thread below this at the moment)
Would appreciate it if you get a chance to give it some thought
Many thanks
Douglas
Post #630133 30th Apr 2022 12:05am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
WOW Shocked Shocked Good job hope it all works well in the end David Thumbs Up
Post #630139 30th Apr 2022 7:08am
Gsxr1250dave
Nice work Thumbs Up
Post #630149 30th Apr 2022 9:30am
dhallworth
Is 11am to early to start drinking!?!?
Spot the difference:
The first picture is of the drivers side head. The second picture of the passengers side head.
The cam lobes on the drivers side head line up with each other and the chan is nice and flat.
The cam lobes on the passengers side head aren't in line and the chain looks like a 🤬 humpback bridge. The chain has so much slack in it that the tensioner is fully extended.
Looks like my tales of not doing the heads were a joke, eh!
Post #630162 30th Apr 2022 11:09am
Look on the bright side Very Happy
It will run much better after that is sorted
I feel your pain
Douglas
Post #630180 30th Apr 2022 12:44pm
Merchy
Ouch!!!! Just when you thought that you were near the end Big Cry I believe that the sun is over the yardarm by 11.00 hrs Sir
but, look on the bright side......
You already have those lovely shiney new heads
Doing the chains / tensioners and maybe the heads means you will almost have a new engine.
Lastly, it gives muppets like me an excellent read when you post about all your hard work Sir Bow down Bow down Bow down
I think it may be time to reward yourself with a large libation, add some tasty comestibles and call it a hydraulic lunch Very Happy
Post #630182 30th Apr 2022 1:09pm
dhallworth
I guess it’s lucky I found it before or skipped teeth or snapped. If it had skipped or snapped it would have made one hell of a mess.
Every cloud n all that. Although it certainly didn’t feel like it a couple of hours ago!
Timing chain kit:
https://www.ebay.co.uk/itm/254637686954?mk...media=COPY
Special tools for removing crank pulley and setting timing I’ve bought from Piet Smile
Cylinder head gaskets are £71 each.
Exhaust manifold gaskets aren’t expensive.
Timing cover gaskets aren’t bad either.
The rest of the gaskets are in a box I collected from Taggarts this morning.
It’s another thousand pounds going into it though. 😫
Maybe we add a power upgrade twist at the same time… 🤔 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #630189 30th Apr 2022 2:33pm
dhallworth
Just priced everything up…
LH Head Gasket - £70.56
RH Head Gasket - £70.56
LH Manifold Gasket - £35.41
RH Manifold Gasket - £35.41
Large Front Timing Cover Gasket - £28.24
Small Front Timing Cover Gasket - £27.32
Timing Cover O-Ring - £5.83
Crankshaft Oil Seal - £37.36
Charge Cooler Gaskets - £74.72
Valve Cover Grommets - £31.20
Cam Sprocket Bolts - £11.12
Tensioner Bolts - £31.64
Crank Pulley Bolt - £9.55
Total in gaskets and bolts - £463.78.
That’s on top of the £180 I spent at the dealer this morning for all of the intake gaskets and injector o-rings.
Then there’s the timing chain kit on top of that at £465.
Best don my crash helmet before venturing home from the workshop this evening!
Here’s a video showing the difference in the chains:
The first chain which is still tight is the one on the drivers side head. The second is obviously the passengers side head.
What’s surprising is it had a miss when cold but was incredibly smooth once warmed up.
Post #630226 30th Apr 2022 7:56pm
TBF half of that is because you have a seat of heads on the shelf and are going to swap them in.
Do they need replacing? Or is it your belt and braces approach to this car (which I don’t disagree with). If existing heads aren’t too bad can you sell to recoup some of this outlay.
Douglas
Post #630237 30th Apr 2022 8:38pm
dhallworth
My car has had LPG on it for years. The AJV8 engines suffer on LPG due to the valve seats being soft.
I can’t get feeler gauges between my cams and tappets meaning that the seats have worn so the heads need to be swapped to get everything back within spec. Either that or have the valve seats changed in the current heads.
No point going this far and reassembling it without doing the job properly! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #630242 30th Apr 2022 8:57pm
Thanks
That makes sense then Thumbs Up
Post #630248 30th Apr 2022 9:36pm
