Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
@Superspoons - I've probably gone way OTT with mine due to the fact I've had the ramp. I've probably done a fair amount of work that it didn't actually need. Not like me to go charging straight in though apparently...
25th Apr 2022 12:56pm |
Following on from my PCV thread here: https://www.fullfatrr.com/forum/topic63251.html
28th Apr 2022 9:23pm |
Tonight saw a bit more time on the lathe to make an adapter for the smoke tester
29th Apr 2022 10:55pm |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 |
Hi David
29th Apr 2022 11:05pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
WOW Good job hope it all works well in the end David |
30th Apr 2022 6:08am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 896 |
Nice work |
30th Apr 2022 8:30am |
30th Apr 2022 10:09am |
Look on the bright side
30th Apr 2022 11:44am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Ouch!!!! Just when you thought that you were near the end I believe that the sun is over the yardarm by 11.00 hrs Sir
30th Apr 2022 12:09pm |
I guess it’s lucky I found it before or skipped teeth or snapped. If it had skipped or snapped it would have made one hell of a mess.
30th Apr 2022 1:33pm |
Just priced everything up…
30th Apr 2022 6:56pm |
TBF half of that is because you have a seat of heads on the shelf and are going to swap them in.
30th Apr 2022 7:38pm |
My car has had LPG on it for years. The AJV8 engines suffer on LPG due to the valve seats being soft.
30th Apr 2022 7:57pm |
Thanks
30th Apr 2022 8:36pm |
