Home > Technical (L322) > Steering Column Tilt Broken
Page 1 of 4 1234>
dan_uk_1984
Not just not moving but completely floppy. The tabs on the adjuster have broken off.
Anyway, I've ordered a new column - £150 eBay thankyou V much. In the mean time I've "modified it" so the adjuster is on the other side (last pic). It wont move up or down and is stuck in the up position.
Stolen from RR.net:
xxDSC01069 by d86cfv, on Flickr
xxDSC01074 by d86cfv, on Flickr
xxDSC01085 by d86cfv, on Flickr
Post #61753 27th Apr 2011 9:05pm
daveo
will that be complete column out Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #61754 27th Apr 2011 9:19pm
dan_uk_1984
Think so. Will take it to my indy as I really don't fancy that job.
Homefully will make a few bob from my old column. May even look at re-designing the weak components like the motor clips or these evil tabs...
Post #61759 27th Apr 2011 9:52pm
M44K TS
Ouch, that isn't going to be an easy job to do I'm guessing. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #61762 27th Apr 2011 10:13pm
herman maire
Canada
dan_uk_1984 wrote:
Think so. Will take it to my indy as I really don't fancy that job..
I dont blame you Laughing its probably not that bad of a job though. 2003 RR 4.4 only 40k miles (current)
2004 RR 4.4 ( just sold)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #61764 28th Apr 2011 2:50am
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I had the same problem on mine afew months back. Luckily the warrenty company paid out. Would have been near the £900 to get in done and that was with my old column as a swap. Indy told me near £1600 for a brand new fitted.
Dan is the new column that you have ordered the updated version? LR updated the columns to stop this common problem. The newer one's have a longer brass spindle so it want "over screw' and snap that little metal stopper. The only down side to the updated column is that the steering wheel no does not tilt as much as it did due the the brass spindle being larger so wont turn as much. Its only a very slight difference but enough for the wife to notice Shocked
Anyway £150 for a column on ebay is a bargain Thumbs Up
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #61768 28th Apr 2011 7:00am
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
They be my photos....
The tabs can easily break especially if anyone leans on the steering wheel when they get out.
Very poor design to have to replace the whole column and not just the broken tabs Sad
Cost me £90 labour to get a new one fitted (3 hours work) but all worked ok after that. L322 2002 4.4 V8 LPG
Post #61997 28th Apr 2011 7:35pm
dan_uk_1984
CyberMrT wrote:
They be my photos.....
And very good they are too! I've even stolen your temp fix!
D
Post #62006 28th Apr 2011 7:51pm
dan_uk_1984
Sorted now:
£150 Used Steering Column (part# QMB000160)
£50 Labour
The column was taken from a 2009 car, marked as NAS spec, it all worked although the steering angle sensor needed swapping over.
Post #62763 5th May 2011 5:05pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Would you believe it,mine went yesterday,exactly the same as yours Dan. HELP !!! Big Cry Big Cry Big Cry
Post #62818 6th May 2011 10:31am
dan_uk_1984
You can bodge it as I did above, then set a saved search on eBay for Range Rover Steering Column and as soon as one comes on buy it. They go from 100-200 depending on whether they are used or newish.
Ring these guys, they are the ones got mine from, he may have some left:
http://cgi.ebay.co.uk/Range-Rover-Power-St...588dc77cab
As above, I paid £50 to have mine replaced, so I wouldnt expect to pay more than £100 for fitting.
Dan
Post #62823 6th May 2011 11:14am
piersie
Thanks for that Dan, i have just phoned him,alas he is a Jaguar dealer, and had to buy some RR bits as a job lot with Jag bits. He is now sold out and unlikely to get any more.
So now i have a feeling this is where i shall get stuffed, i will no doubt get charged 12 grand for a column plus 2 grand labour. I kid you not,they just always see me coming. Sad Thumbs Up
Post #62839 6th May 2011 12:17pm
dan_uk_1984
There was one on the other day as a buy it now for £200ish. They do come up.
Like I said, bodge it so its safe, thats a relatively easy job in comparison.
Post #62844 6th May 2011 12:53pm
piersie
Thanks Dan i have just bodged it, it is obviously a weak link ,as it appears so many snap. I would expect a far stronger design.
Have phoned loads of places,and made loads of on line searches,nothing as yet.
Onwards and upwards. Thumbs Up
Post #62847 6th May 2011 1:08pm
piersie
As i said they do see me coming.
Have just phoned a used parts dealer in Louth. £700 +Vat +a £200 charge returnable when i send them my broken one.
Ill stick with fleabay. Sad
Post #62851 6th May 2011 1:26pm
Page 1 of 4 1234>
