![]() | Home > Technical (L322) > Steering Column Tilt Broken |
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 ![]() ![]() ![]() |
http://www.rangerovers.net/repairdetails/steering/tilt3.html |
grant Member Since: 06 Jun 2011 Location: Dunmow Posts: 24 ![]() ![]() ![]() |
My tilt works OK, but the reach is does not move - it's fully in. I've only got little arms!
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
I have just bought a 2007 which had the famous wheel in the lap when you put the key in. The TSB from LR tells dealers to first replace the switch pack, and then if there is still a problem, the tilt motor, which makes a tidy sum out of warranty, so I decided to dismantle the tilt motor. The problem that I found, and I suspect it is common, is that the motor drives a nylon worm gear, that is mounted on an axle, which in turn drives the square key that drives the tilt screw - the axle loses "grip"on the nylon cog. Every time you key out, the ECU pulls the column up and looks for a stall; as the cog slips on the axle, there is no stall and so the ECU thinks it has been raised through the roof. When you put the key back in, it tries to return the wheel to where it thinks it should be - in the car and not on the roof, hence the leg cut off syndrome. This is because the ECU does not know absolutes, only the time the motor has been running. My solution, which cost considerably last than a new motor, was to add a "blob" weld to the centre of the axle, grind it to a square key, and then cut a corresponding slot in the nylon cog. Works a treat. This ensures that the motor stalls correctly, and that the ECU then stops the motor, so it no longer loses track of where the wheel is. Sorry, no photos, but it is a fairly simple job, and more durable than a new motor which will eventually fail in the same manner - essentially a bad design! I saw (or rather heard) similar motor runing at max height in my 2002, so I guess they have the same issue, although the softawre must work differently, as I did not experience the wheel in lap issue. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
the RAC unit can switch off the steering tilt but only works on 2002 to 2005... |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I might have to play with this feature, I am thinking of turning mine off so that it stays where it is and does not move in and out everytime I turn the engine on or off. Reformed |
its only one click and it'll save wear on the motors i suppose... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
My IIDTool just arrived I wonder if I can turn the feature off on my 2007, will try over the weekend. Geoff |
Could I not just Araldite the nylon cog in place or am I missing something? Geoff |
let us know how you get on geoff ,sounds like steves produced an interesting tool... |
Well I disabled the auto move every time you start/turn of the engine. Now I can adjust it as I want, and when I turn the engine of it stays where it was. Reformed |
Probably not for two reasons. First the axle supports the cog and has to be pressed though it to remount the "gearbox"; and secondly, I have never managed to get araldite to grip on nylon. One possibility would be to replace the weld blob with an araldite key, but the forces in this motor are significant; when you see how tight the cog is on the axle, you could well believe it is OK - thats why it still raises and lowers the steering wheel - but against the limits, the motor is sufficiently powerful to move the axle inside the cog! A weld blob works, but the motor may be strong enough to displace araldite. Another alternative may be to drill a hole in the axle and insert a spiral pin, but this would weaken the axle, and require more cutting in the cog. Hope this helps |
Thanks, I think I'll just leave it as it is for now as I haven't got access to welding gear and I can't just pop round to your house and get you to put a blob of weld on the shaft ![]() |
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 35 ![]() ![]() |
I think that I should pull apart the connector to save me having this problem. Mine is a 2004 so its has a god few ins and outs.
