Home > Technical (L322) > Tdv8 no start |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
If you've got a 'second' key....try that. That will/could eliminate the battery inside the key fob.
9th Nov 2020 8:08am |
Badgeruss Member Since: 08 Nov 2020 Location: Essex Posts: 6 |
Thanks I have tried both keys |
9th Nov 2020 8:56am |
OK, that's eliminated the keys then!
9th Nov 2020 9:24am |
Thanks appreciated your reply.
9th Nov 2020 9:27am |
If you put your headlights on & they're bright, you can possibly discount an undercharged battery?
9th Nov 2020 9:30am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
IIRC the hard reset is
9th Nov 2020 11:05am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Make sure the battery is fully charged.
9th Nov 2020 9:26pm |
So eventually found the time to time to try and fix the my problem during daylight hours this weekend.
15th Nov 2020 5:51pm |
**pic has been placed in the gallery |
15th Nov 2020 5:54pm |
