Home > Technical (L322) > Tdv8 no start
Badgeruss
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Tdv8 no start
hi, any help appreciated.
My 2010 Tdv8 will unlock and radio etc works and also the dash screen is on the sunset screensaver but when I press the start button the screen doesn't change to the dials screen for ignition. The engine doesn't even attempt to crank, no noises at all or warning messages about the key not present.
Is this a faulty start button? As nothing is happening or is this a battery fault?
Has anyone had this issue?
Post #572239 9th Nov 2020 7:47am
Fox889
If you've got a 'second' key....try that. That will/could eliminate the battery inside the key fob.
Then you need a meter across the main battery to see what she says.
That's all I can come up with so far, sorry. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #572241 9th Nov 2020 8:08am
Badgeruss
Thanks I have tried both keys
Post #572247 9th Nov 2020 8:56am
Fox889
OK, that's eliminated the keys then! Smile
You could try a 'hard reset' which I believe [emphasis on the word believe] is disconnect the battery, wait 5 minutes & reconnect.
The sequence for starting the car is.....foot on brake & push start button. If you don't touch the brake & merely push the start button, which in theory should just give you 'ignition' the dash should change? If nothing different happens, it could be the stop/start button.
I've had a quick 'google' & this appears to be fairly common on Land Rovers of various guises. Consensus of option is, that if you push the button enough times it will eventually start.
Running out of ideas, sorry. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Post #572249 9th Nov 2020 9:24am
Badgeruss
Thanks appreciated your reply.
Any ideas help.
I'll try and disconnect the battery.
Post #572251 9th Nov 2020 9:27am
Fox889
If you put your headlights on & they're bright, you can possibly discount an undercharged battery?
It's intriguing that's for sure. Keep us posted Smile 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Post #572253 9th Nov 2020 9:30am
rjff
IIRC the hard reset is
Switch off the car and let it go to sleep.
Remove both battery leads in the correct order, wait a few minutes and then touch the leads to each other for several seconds, NOT the battery.
Reconnect the leads in the correct order.
If it does turn out to be the engine start button, then this thread is great for replacement info. (Thanks to Simon, TTB)
https://www.fullfatrr.com/forum/topic44592.html Cheers
Richard
Gap IIDBT
Post #572262 9th Nov 2020 11:05am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Make sure the battery is fully charged.
My battery is about 5 years old and if it is not used or charged weekly I find It will not start the engine. Don't even get a click off the starter or any errors 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #572314 9th Nov 2020 9:26pm
Badgeruss
So eventually found the time to time to try and fix the my problem during daylight hours this weekend.
But by now the car wouldn't unlock, so all pointed to the vehicle batter being flat, which it was and now replaced.
The only problem in the meantime is that I have no key blades to unlock the vehicle, absolutely typical!!
An auto locksmith came out and broke into the car for me to enable me to change the battery.
I asked him to cut me 2 key blades for my keys, he has been struggling to do so due to the splines in the passenger door lock being plastic and most probably deteriorated over time due to lack of use, as only used in emergency scenarios such as this.
So my next question is does anyone know where I can source a new door lock barrel unit ? Pic attached
Post #572935 15th Nov 2020 5:51pm
Badgeruss
**pic has been placed in the gallery
Post #572936 15th Nov 2020 5:54pm
