![]() | Home > Technical (L322) > Tdv8 no start |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 ![]() ![]() ![]() |
If you've got a 'second' key....try that. That will/could eliminate the battery inside the key fob.
Badgeruss Member Since: 08 Nov 2020 Location: Essex Posts: 6 ![]() ![]() ![]() |
Thanks I have tried both keys |
OK, that's eliminated the keys then! |
Thanks appreciated your reply.
If you put your headlights on & they're bright, you can possibly discount an undercharged battery?
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
IIRC the hard reset is
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Make sure the battery is fully charged.
So eventually found the time to time to try and fix the my problem during daylight hours this weekend.
**pic has been placed in the gallery |
