Home > Technical (L322) > Poorly TD6
Page 2 of 3 <123>
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
The mystery deepens.
I cleared the fault codes this morning. Checked the connectors on the loom for corrosion and then pull the connector off each injector in turn.
Am I right in my belief that the cylinders run front to rear? So cylinder #1 is closest to the radiator? I was monitoring the live data and pulled the loom connectors one at a time front to rear. When I pulled #2 (the first injector flagged up) the reading for injector #3 decreased?
Would this indicate a problem with the loom?
I found a thread on Landy Zone that suggested that the external low pressure fuel pump can cause injector problems?
Jim
Post #572264 9th Nov 2020 11:27am
Paul thornton
Yep, number 1 is closest to the radiator as you say. I'm not sure how the values work on the newer iid tools as I had a non bluetooth version which just displayed +/- mm2 figures and the lower the number the better if I remember correctly....
Mine was showing something like +6 for injector 1 wheras all the others were showing minus figures apart from one (can't remember which) as it was trying to compensate. When I pulled the plug on no1 it made no difference whatsoever to the idle hence flagging an obvious fault.
Post #572265 9th Nov 2020 12:00pm
jim4244
A question for the technical experts.
Can I used a BMW injector loom instead of a Land Rover one? They look identical but the BMW one is £125 cheaper.
Jim
Post #572293 9th Nov 2020 7:35pm
Paul thornton
Are they the same length? How much are they as last time I enquired they were around £350? I'd be tempted to prove it faulty first but your call I suppose.
Post #572294 9th Nov 2020 7:53pm
Jayk69
check the part no on the interweb i imagine they are the same as everything seemed to be BMW
Post #572295 9th Nov 2020 7:54pm
wayneg
Jim
In your original post, it shows a low-pressure reading of 3.85bar. That is pretty healthy. Stick with the easy part 1st, do a continuity test of the loom, if OK I would then buy cheap used injectors from eBay, check the spray pattern and swap them out with the 2 suspect ones. Depends on how much you want to spend and what you can DIY. If you are going to remove the injectors yourself get a puller.
https://www.ebay.co.uk/itm/M8-M12-M14-Dies...SwA1tfdiQH 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #572338 10th Nov 2020 5:29am
this wheeler dealer episode shows ED testing the injectors and wiring loom, might help,
https://www.dailymotion.com/video/x6ymxbd ... - .- -.
Post #572345 10th Nov 2020 8:48am
@ 15:30 onwards .
Post #572358 10th Nov 2020 10:48am
jim4244
Thanks guys!
That video was really helpful. Strange how it was a mirror image with everything reversed?
I did the continuity test as shown and it appears to be a problem with the injector rather than the loom. So I guess that I will have to bite the bullet and pick up a couple of reconditioned injectors, swap them out and cross my fingers...
Question - would you change the injectors yourself or put it into a garage?
Jim
Post #572376 10th Nov 2020 4:55pm
wayneg
It's a straight forward DIY if you have the confidence. No 1 comes out easily but the rest requires removing the inlet manifold. I would say no longer than an hour to get full access. Here is where the fun can start if the injectors are stuck. Don't start without a puller at hand. What I do is put rotational pressure on the injector while banging up with the puller/slide hammer. Slowly getting the injector moving side to side and hopefully up and out. Plenty of penetrating oil down the hole as soon as you can to give time for it to soak in. Be mindful of plastic parts you might be levering against and that there is a lot of pressure in the fuel rail to be released. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #572431 11th Nov 2020 12:42am
Paul thornton
I was lucky as it was injector number 1 so no inlet manifold removal required. I took advice from someone on here and loosened the injector securing nuts and fired the car up. Engine compression then popped the injector loose! I have heard stories of slide hammers etc being used though....
Post #572460 11th Nov 2020 9:53am
jim4244
Well I have given the offending injector (#2) a good squirt of Plus Gas and will leave it to soak while I source a replacement.
I had intended to just remove the injector and drop it off for refurbishment. A local Bosch centre has quoted me £165 +VAT to carry out a referb, which seems high to me?
Anyone here any recommendations?
The other thing is initially only injector #2 was flagged up when I ran a live values test. When I cleared the codes and ran a second test it showed problems with #2 and #6. Is this the engine trying to balance itself or should I replace both?
Jim
Post #572469 11th Nov 2020 10:42am
jim4244
This was the initial live value test.
This is the current one.
Post #572470 11th Nov 2020 10:44am
Jayk69
I would start with 2 then re-test if no 6 needs replacing after then do it. i think your quote for a Bosh registered garage to refurb the injector is ok, but you may want to try ebay 1st.
if my memory serves me right no6 can be a pig to do as access is very tight. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #572472 11th Nov 2020 10:48am
jim4244
So just bite the bullet, order 2 and replace them both?
Jim
Post #572474 11th Nov 2020 10:57am
Page 2 of 3 <123>
