Home > Technical (L322) > Poorly TD6
Page 3 of 3 <123
Paul thornton
There's a thread on here I started around 3 years ago named 'TD6 INTERMITTENT JUDDER / INJECTOR FAULT '
Have a read through there. Someone recommend a place who sell injectors on ebay so the link should be in the thread somewhere but I'm sure it was around £100 + a £30 refundable surcharge when you send your old one back. They were a really knowledgeable diesel specialist so well worth using.
Post #572478 11th Nov 2020 12:24pm
wayneg
I have got refurb ones off ebay in the past for 80 pounds and they have been great. I have also bought used ones for around 30 pounds also no problems.
https://www.ebay.co.uk/itm/BMW-E39-E46-330...SwudpfisTK 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #572553 12th Nov 2020 1:14am
wayneg
This is the eBay refurb firm I have used, injectors came with new nozels and washers... http://www.ebaystores.co.uk/PF-Jones-Manch...08418& 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #572554 12th Nov 2020 1:19am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Well........I’m totally lost now......
Spent the day yesterday replacing injector #2 & #6. Put it all back together and now have exactly the same problem but this time with injectors #2 & #6😖
All this appeared to start after I had problems with a vacuum hose pipe. Could it be a vacuum system or fuel sensor fault causing false readings at the injectors?
Jim
Post #573179 17th Nov 2020 12:27pm
Jayk69
sorry to hear that Jim, but did you test the loom? and before you changed the injectors di you do the bottle test? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #573202 17th Nov 2020 2:38pm
322BLL
Estonia
Should the injector live values be constant number at idle? I have 2 with constant 655 reading and 4 that change between 0 and 655.
Post #574462 28th Nov 2020 9:25pm
Page 3 of 3 <123
