![]() | Home > Technical (L322) > Poorly TD6 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Yep, number 1 is closest to the radiator as you say. I'm not sure how the values work on the newer iid tools as I had a non bluetooth version which just displayed +/- mm2 figures and the lower the number the better if I remember correctly....
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
A question for the technical experts.
Are they the same length? How much are they as last time I enquired they were around £350? I'd be tempted to prove it faulty first but your call I suppose. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
check the part no on the interweb i imagine they are the same as everything seemed to be BMW |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
In your original post, it shows a low-pressure reading of 3.85bar. That is pretty healthy. Stick with the easy part 1st, do a continuity test of the loom, if OK I would then buy cheap used injectors from eBay, check the spray pattern and swap them out with the 2 suspect ones. Depends on how much you want to spend and what you can DIY. If you are going to remove the injectors yourself get a puller. https://www.ebay.co.uk/itm/M8-M12-M14-Dies...SwA1tfdiQH 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
this wheeler dealer episode shows ED testing the injectors and wiring loom, might help,
Thanks guys!
It's a straight forward DIY if you have the confidence. No 1 comes out easily but the rest requires removing the inlet manifold. I would say no longer than an hour to get full access. Here is where the fun can start if the injectors are stuck. Don't start without a puller at hand. What I do is put rotational pressure on the injector while banging up with the puller/slide hammer. Slowly getting the injector moving side to side and hopefully up and out. Plenty of penetrating oil down the hole as soon as you can to give time for it to soak in. Be mindful of plastic parts you might be levering against and that there is a lot of pressure in the fuel rail to be released. 2007 TDV8 VSE
I was lucky as it was injector number 1 so no inlet manifold removal required. I took advice from someone on here and loosened the injector securing nuts and fired the car up. Engine compression then popped the injector loose! I have heard stories of slide hammers etc being used though.... |
Well I have given the offending injector (#2) a good squirt of Plus Gas and will leave it to soak while I source a replacement.
This was the initial live value test.
I would start with 2 then re-test if no 6 needs replacing after then do it. i think your quote for a Bosh registered garage to refurb the injector is ok, but you may want to try ebay 1st.
So just bite the bullet, order 2 and replace them both?
