Home > Maintenance & Mods (L322) > Rear Windscreen (Tailgate) Side Moulding |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The original trims should have tabs as well, sometimes they snap off when you try to remove the trims. I recently replaced my tailgate trims and used a stanley knife blade to get the old (snapped off) tabs out from under the window glass. The tabs are there to keep the trim in place and shouldn't be cut off. It can be a bit fiddly getting the tabs into place when fitting, best thing is to leave the tape on, locate the tabs under the glass then carefully pull the tape off whilst keeping the tabs in place with a small screwdriver or bit of plastic. It's also why the tabs have an extra long tape 'tail' on them. |
21st Oct 2020 6:06pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Brilliant, thank you Discotigger. Boing! |
21st Oct 2020 8:44pm |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 |
Binned mine! |
21st Oct 2020 10:39pm |
23rd Oct 2020 10:57am |
Yep, makes the tailgate look a bit tidier too! |
23rd Oct 2020 3:41pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Dammit, never even realised that mine were missing
5th Apr 2021 10:24pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
on my 2010 it has never had them fitted ( bought it 3 years old ) and first owner was my brother |
6th Apr 2021 3:25am |
