Home > Maintenance & Mods (L322) > Rear Windscreen (Tailgate) Side Moulding
Range Rover L322
Hello there,
I know most people remove and bin these mouldings as they do little other than stop drips when the tailgate is open, however I am Lockdown bored and looking for things to fix...
I am stuck with what the tab on the bottom does! (circled). It doesn't exist on my originals... I initially thought it needed to be cut off and used elsewhere, but now I am beginning to think it's a mod to hold the bottom of the moulding laterally onto the window.... does anyone know or have any ideas?
Post #570533 21st Oct 2020 6:12pm
Discotigger
The original trims should have tabs as well, sometimes they snap off when you try to remove the trims. I recently replaced my tailgate trims and used a stanley knife blade to get the old (snapped off) tabs out from under the window glass. The tabs are there to keep the trim in place and shouldn't be cut off. It can be a bit fiddly getting the tabs into place when fitting, best thing is to leave the tape on, locate the tabs under the glass then carefully pull the tape off whilst keeping the tabs in place with a small screwdriver or bit of plastic. It's also why the tabs have an extra long tape 'tail' on them.
Post #570543 21st Oct 2020 7:06pm
Range Rover L322
Brilliant, thank you Discotigger. Boing!
Post #570579 21st Oct 2020 9:44pm
MAF260
Binned mine!
Post #570593 21st Oct 2020 11:39pm
Range Rover L322
Best £50 I've ever spent Laughing Laughing Laughing
Post #570717 23rd Oct 2020 11:57am
Discotigger
Yep, makes the tailgate look a bit tidier too!
Post #570749 23rd Oct 2020 4:41pm
Merchy
Dammit, never even realised that mine were missing Embarassed Whistle
Another item to add to the shopping list, will look much tidier when fitted. Thumbs Up
Post #590383 5th Apr 2021 11:24pm
darrenm
on my 2010 it has never had them fitted ( bought it 3 years old ) and first owner was my brother
Post #590392 6th Apr 2021 4:25am
