Home > Technical (L322) > Odd tyre wear
Mark T Boldry
Odd tyre wear
My 2012 L322 4.4 is showing odd tyre wear... ONLY on the LHS..!
What are your thoughts... The LHF is the worst (in two pictures) and the other is the LHR. The wear is on the outer edge only.
Pirelli Scorpion 255/50/20
New tyres ordered today (Yokohama Geolander)
Thanks in anticipation,
Mark.
Post #569665 12th Oct 2020 10:54pm
coopss
Alignment ok? Cornering/roundabouts at speed can do this from what I’ve read on here.
What drew you to the Yokohama’s? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #569668 13th Oct 2020 12:31am
Paul thornton
Quite normal that on the L332 's I think? Mine was the same.
Post #569669 13th Oct 2020 12:35am
Mark T Boldry
It’s not alignment as far as I can see.. with out of alignment, one gets similar wear patterns on tyres on the same axle...
I like the roundabout cornering / roundabout theory.. I had this in mind, but wanted to hear the same from others..
Re the Yokohama Geolanders... I had a Land Rover Series 3 Stage 1 Safari in Australia that I put a set on, they were amazing..! I also ran a set on an Austin Healey 100 that we prepared for the Peking / Paris event a couple of years ago... Over the entire event, they had NO tyre problems whatsoever...! That sort of sold me on the Geolanders... Smile
Sadly the imige won’t load correctly..
Post #569672 13th Oct 2020 7:41am
GGDR
outer shoulder wear on the front is typically lower suspension arm / bush.
Somebody correct me if I'm wrong
this one usually
. Cheers, Greg
Post #569673 13th Oct 2020 7:49am
Fox889
Greg:
Mmmmm my two front Conti's wore like that, had it 3d aligned last year then had a full set of Pirelli's on for this years MOT.
Would that bush also affect wheel balance as mine still has a slight steering wheel wobble....as it did before with the old Conti's even though they're new & been balanced? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #569674 13th Oct 2020 8:28am
GGDR
not sure about wobble.
but it is a wear part i.e. consumable with a finite life.
it's relatively easy to get a good look at it
. Cheers, Greg
Post #569675 13th Oct 2020 9:09am
D3Jon
I'd agree that wear in that arm's bush can cause uneven tyre wear. I've just replaced both mine as they were looking less than perfect. That bush doesn't wear out all that quickly, not as fast as the lower arm's ball joint.
However, the arm you've photo'd is actually known as the upper arm (not lower), despite them both effectively being lower arms! Very Happy
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #569689 13th Oct 2020 11:35am
