Home > Technical (L322) > Odd tyre wear |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Alignment ok? Cornering/roundabouts at speed can do this from what I’ve read on here.
12th Oct 2020 11:31pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Quite normal that on the L332 's I think? Mine was the same. |
12th Oct 2020 11:35pm |
Mark T Boldry Member Since: 08 Feb 2019 Location: York Posts: 29 |
It’s not alignment as far as I can see.. with out of alignment, one gets similar wear patterns on tyres on the same axle...
13th Oct 2020 6:41am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
outer shoulder wear on the front is typically lower suspension arm / bush.
13th Oct 2020 6:49am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
Greg:
13th Oct 2020 7:28am |
not sure about wobble.
13th Oct 2020 8:09am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 418 |
I'd agree that wear in that arm's bush can cause uneven tyre wear. I've just replaced both mine as they were looking less than perfect. That bush doesn't wear out all that quickly, not as fast as the lower arm's ball joint. However, the arm you've photo'd is actually known as the upper arm (not lower), despite them both effectively being lower arms! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
13th Oct 2020 10:35am |
