![]() | Home > Technical (L405) > L405 2014 Vogue Knocking Noise |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Very difficult to say from that.
M99TYK Member Since: 07 Jun 2019 Location: Tyne and Wear Posts: 50 ![]() ![]() ![]() |
Yes mate it’s stuttering and shuddering loads with revs.
Sounds bad.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Ouch, that doesn't sound healthy.
Would this be something covered by warranty? |
Depends on the warranty?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Owww don't start it again whatever you do! Sorry, but i think you've already guessed the outcome! |
That’s not good and is a real shame on what seems to be a nice car.
I certainly will keep you all updated.
You sound like you’re in a relative position of strength as a starting point. Low mileage car bought in good faith as AU from franchised MD and since serviced and maintained in accordance with manufacturer’s recommendations by the same franchise group.
Depends on what warranty they gave you with the car.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
That sounds like its done a big end...
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
is the fluid running out toward the end of the second video related? if so, it might not be a bottom end issue? |
Just a quick update.
