![]() | Home > Technical (L405) > L405 2014 Vogue Knocking Noise |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
Awesome result |
M99TYK Member Since: 07 Jun 2019 Location: Tyne and Wear Posts: 50 ![]() ![]() ![]() |
jc132jc Member Since: 05 Nov 2019 Location: Suffolk Posts: 32 ![]() ![]() |
WOW |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Wow, that is completely bad luck |
that's |
Farnellās service/ maintenance related communications processes are unacceptable IMO. Getting past the remote, clueless call ācentreā triage set up such that you are actually connected to your garage of choice is difficult... then trying to get a service person at your garage of choice to take your call and/ or reply to a reasonable email enquiry in an intelligible manner is more difficult.
The service manager from Stratstone called to update me this evening. They have been in touch with various service centres to search for a tool which allows them to complete an oil pressure test. Apparently they have never been asked by LR before to perform this test due to the engine being ābombproofā and the only common issue being the crankshaft which is very much diagnosable by finding metal in the oil/filter. They have had to fabricate this part in order for them to carry out the oil pressure test.
*Update*
The car has had the new engine fitted (3rd) and after a couple of weeks an agreement made in which I dropped it off at Stratstone Newcastle and said goodbye. It feels good to walk away from a problem which from the start has never felt right. Iām sure Iāll find myself in another LR one day but for now Iām going to enjoy a motor that I can rely on and not worry each time I hear a small sound from the engine bay or a knock from the suspension. Maybes one day when I can afford catastrophic failures or a new one with a warranty Iāll be happy.
Well at least itās an outcome you are happy ish with.
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
That's a good result for you by the sounds of it. Can you imagine if you took a gamble and went for it without the warranty! Surely they aren't going to stick that on a forecourt now on its third engine, I'd imagine that would be off to auction? |
