![]() | Home > Technical (L405) > L405 2014 Vogue Knocking Noise |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
A set of big end bearings we pulled out if a 2016 RRS this week
M99TYK Member Since: 07 Jun 2019 Location: Tyne and Wear Posts: 50 ![]() ![]() ![]() |
[quote="Mikey"]A set of big end bearings we pulled out if a 2016 RRS this week
RAC Warranty
At least Mikey, your example proves that problems like that can be covered by a decent warranty. |
Oil starvation caused by rotation of bearing |
And for the lay person this means/ the point you’re trying to make is? 😂 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Poor design.
Definitely not a poor design. Warranty company will likely reject it as a "design issue" as per the LRA Warranty |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Thon penny has just dropped 😂 |
Just stating the obvious, obviously |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Same happened to my TDV6 at the start of last year...
Kev, what MY were they tabbed from? |
I'm not sure to be honest Mike. I know someone over on the Disco forum modified his journals to accept the new tabbed bearings though. Apparently it was a fairly easy mod to make so may be worth doing if the opportunity presents itself. Kev
