Home > Maintenance & Mods (L405) > SVO arm rest adjuster
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
Has anyone fitted them to a facelifted car? The clip is different than Powerful Uk Ltd video and I can't get it out...
Seems to be my story today of not being able to do things on the car... SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #564493 13th Aug 2020 4:44pm
notanrdx
United States 2017 Range Rover TDV6 Fuji White
Ran into the same issue on my 17. Found this less than ideal video.
https://cloud.video.taobao.com/play/u/1789...908638.mp4
I ended up just grabbing the flat spot on the white clip with a small pair of needle nose vice grips and pulling sideways
If you have gotten the armrest apart to where you can see the clip, you are past the hard part IMHO.
Good Luck
Post #564521 13th Aug 2020 7:40pm
luxmoggy
Thank for this I will have one more try tonight... I was going in the right direction... SDV8 AB MY 2020
Post #564522 13th Aug 2020 8:07pm
luxmoggy
That worked, how did you get the top off of the arm rest... I did it but not sure what caused it to happen. Would like to do the second one easier... SDV8 AB MY 2020
Post #564542 13th Aug 2020 10:03pm
notanrdx
Did you remove the armrest top? If so, look about 3" (8cm) in from the rear, there is a plastic ramp the holds everything together. I got mine off, by prying gently up at the very rear (to clear the lip) and at this point (about 3" in) while sliding the top forward. The top should pop forward a bit, and then just lift off. Goes back together by pushing top to the rear. Once you have it apart, its pretty obvious how its wants to go back together.
Good luck.
Post #564547 13th Aug 2020 11:46pm
luxmoggy
All complete....
 SDV8 AB MY 2020
Post #564575 14th Aug 2020 4:50pm
notanrdx
Nice! Now you need the coat hooks Smile
Post #564578 14th Aug 2020 4:55pm
notanrdx
...and the shift knob.
Post #564579 14th Aug 2020 4:56pm
luxmoggy
I will think about those bits... doing some other stuff on the car at the moment... SDV8 AB MY 2020
Post #564599 14th Aug 2020 7:05pm
Looks great Thumbs Up
Post #564619 15th Aug 2020 2:39am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
The coat hooks I thought you could just pop off an existing cover or hook and pop these the autobio ones on? Guess not. Looks like you have to remove the b pillar panel and then drill into it/screw into it. No thanks. I have extended leather so not drilling into that. Would have been a nice touch though 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #564621 15th Aug 2020 4:19am
luxmoggy
Thanks... i don’t think you have to drill for the hooks. The current ones are also screwed in, unless it is different for facelift cars... SDV8 AB MY 2020
Post #564628 15th Aug 2020 8:12am
Remove the B pillar cover and unscrew the securing fixings swap out the hook and resecure & then refit the pillar cover... Easy if a bit fiddly!!! Censored Censored Censored Whistle Thumbs Up
Post #564636 15th Aug 2020 9:32am
horse86
Ah. Not so bad then. Might give em a go 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #564660 15th Aug 2020 2:51pm
zion
United States 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Has anyone found Genuine OEM parts in the US ? How much are they?
Found a set at eBay for $399 but doesn't mention anything about being genuine and I don't want to spend 399 for some crap Chinese stuff
Post #565218 23rd Aug 2020 7:10am
