![]() | Home > Maintenance & Mods (L405) > SVO arm rest adjuster |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
Ran into the same issue on my 17. Found this less than ideal video.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
Thank for this I will have one more try tonight... I was going in the right direction... SDV8 AB MY 2020
That worked, how did you get the top off of the arm rest... I did it but not sure what caused it to happen. Would like to do the second one easier... SDV8 AB MY 2020
Did you remove the armrest top? If so, look about 3" (8cm) in from the rear, there is a plastic ramp the holds everything together. I got mine off, by prying gently up at the very rear (to clear the lip) and at this point (about 3" in) while sliding the top forward. The top should pop forward a bit, and then just lift off. Goes back together by pushing top to the rear. Once you have it apart, its pretty obvious how its wants to go back together.
All complete....
Nice! Now you need the coat hooks |
...and the shift knob. |
I will think about those bits... doing some other stuff on the car at the moment... SDV8 AB MY 2020
Looks great |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
The coat hooks I thought you could just pop off an existing cover or hook and pop these the autobio ones on? Guess not. Looks like you have to remove the b pillar panel and then drill into it/screw into it. No thanks. I have extended leather so not drilling into that. Would have been a nice touch though 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
Thanks... i don’t think you have to drill for the hooks. The current ones are also screwed in, unless it is different for facelift cars... SDV8 AB MY 2020
Remove the B pillar cover and unscrew the securing fixings swap out the hook and resecure & then refit the pillar cover... Easy if a bit fiddly!!! |
Ah. Not so bad then. Might give em a go 2014 FF Autobiography 5.0 SC
zion Member Since: 04 Nov 2019 Location: California Posts: 22 ![]() ![]() ![]() |
Has anyone found Genuine OEM parts in the US ? How much are they?
