Home > Maintenance & Mods (L322) > Rear upper Hub Bush tolerance question (filmclip included) |
peteuusi Member Since: 22 Dec 2015 Location: Tornio Posts: 11 |
Hell,
21st Jul 2020 9:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I cannot view the video without signing up for an account!?!
21st Jul 2020 9:14am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
There shouldn't be any movement. Paul,
21st Jul 2020 9:34am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
Can't see it either, shouldn't be any movement..
21st Jul 2020 9:39am |
https://drive.google.com/file/d/1dHGnczdBl...sp=sharing
21st Jul 2020 9:40am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I'm with you there Pete, had the same issue when I last did some, certainly gave me good workout getting the bolts out. |
21st Jul 2020 9:41am |
Hmmmm, that's not moving the way it would if worn, looks like the bolt is loose and the hub has stretched open... or the joint (it's like an internal Helm joint) is totally gone...
21st Jul 2020 9:54am |
The bolt is tight so new bush. 👍 will by a genuine one ☺️ |
21st Jul 2020 10:10am |
Bush is shot there Petri, looks like its collapsed inside, deffo a new one, as Pete says use genuine, the cheap one's are made of cheese. |
21st Jul 2020 11:06am |
Wow, yes that's knackered sir |
21st Jul 2020 10:34pm |
