Home > Maintenance & Mods (L322) > Rear upper Hub Bush tolerance question (filmclip included)
peteuusi
Finland 2005 Range Rover HSE Td6 Zambezi Silver
Hell,
I have now change the rear shock absorber on both sdes and noticed that there is some movement in the upper hub bush. should it be so? or is it worn? the movemnt is significant. Not side to side but back and forward in the direction of the tire.
Here is teh filmclip https://drive.google.com/file/d/1dHGnczdBl...sp=sharing
-Petri
Post #562221 21st Jul 2020 9:07am
I cannot view the video without signing up for an account!?!
Can you post it on youtube?
Post #562222 21st Jul 2020 9:14am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
There shouldn't be any movement. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #562225 21st Jul 2020 9:34am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Petri. I cannot view your video either, but there should be no free play in the bush. It is a swivel bush, so like a cross between a balljoint and a bush. If you can move the wheel and get play from any direction I suspect it is worn.
Post #562226 21st Jul 2020 9:38am
Can't see it either, shouldn't be any movement..
I did the bottoms as well as they had very small movement...
Get new cam bolts when you change them, my old one was about the age of yours when I did it and the bolts were seized, ended up using a 3/4" HGV rattle gun and it snapped two of them before they let go, lots of heat and hammers needed..!! Pete
Post #562227 21st Jul 2020 9:39am
peteuusi
It should work now Smile
Post #562228 21st Jul 2020 9:40am
diesel Dave
I'm with you there Pete, had the same issue when I last did some, certainly gave me good workout getting the bolts out.
Post #562230 21st Jul 2020 9:41am
Hmmmm, that's not moving the way it would if worn, looks like the bolt is loose and the hub has stretched open... or the joint (it's like an internal Helm joint) is totally gone...
Needs some investigation...
Don't buy cheap ones if you don't want to do it again in 6 months... Get genuine... Thumbs Up Pete
Post #562234 21st Jul 2020 9:54am
peteuusi
The bolt is tight so new bush. 👍 will by a genuine one ☺️
Post #562236 21st Jul 2020 10:10am
diesel Dave
Bush is shot there Petri, looks like its collapsed inside, deffo a new one, as Pete says use genuine, the cheap one's are made of cheese. Mr. Green
Post #562240 21st Jul 2020 11:06am
Wow, yes that's knackered sir Thumbs Up
Post #562303 21st Jul 2020 10:34pm
