Home > Technical (L322) > Adaptive dynamics but not the front !
Jri711
United Kingdom 2010 Range Rover Vogue 4.4 V8 Santorini Black
After a bit of help guys, I’ve got the dynamics fault but it’s coming up as left rear broken wire or open Circuit, now I’ve checked the multi plug & the loom right until it goes up through the floor ( carpet up job ) my question is where is the dynamics module? At lest then I can do a continuity check on that whole loom, going to order a height sensor to rule that out also . Thanks for any help on this.
Post #557551 13th Jun 2020 3:05pm
Baltic Blue
Previous fault reports have shown they break very near the top of the strut very similar to the fronts, but much less common.
Post #557552 13th Jun 2020 3:15pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #557554 13th Jun 2020 3:29pm
Jri711
Cheers guys, least I know where to look now, I’ll get a sensor and fit that the same time.
Post #557556 13th Jun 2020 3:38pm
GGDR
I remember another member had a chaff where the loom came through the body too... Cheers, Greg
Post #557562 13th Jun 2020 5:03pm
Jri711
Checked all these parts of the wiring, & all seams ok but like I said I’ll run a loom check next time I get a chance, but what do you guys think about the level sensor? I mean what’s the odds on just the dynamics side going down as the ride heights all change up & down fine.
Post #557567 13th Jun 2020 5:32pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
That was the issue on mine, chafed wires on the offside rear height sensor, but the ride height functionality worked fine. 2011 TDV8 4.4 AB Bournville Brown
Post #557620 13th Jun 2020 11:42pm
GGDR
Jri711 if you have an IID it will tell you which side too....
. Cheers, Greg
Post #557634 14th Jun 2020 8:05am
Jri711
Ok, had a bit of a look today, from my left rear sensor it seams I have Continuity On pins 2 ,6 & 3 nothing on 1 ,4 & 5 I’ve also done the same test once the loom is inside the car under the rear seats/carpet with the same results, my questions are do all the wires from the sensor go to the ADM ? If not where do they or if so can anyone tell me which pins do 1,4 & 5 go to because I can’t seam to be able to distinguish the colours on the ADM ? If this is a break in the loom where the hell else would you look? There’s no damage anywhere I’ve looked on the loom. If they do go else where & the loom turn out to be ok what’s the chances of a height sensor going down on just the ADM side & has anyone else had that fault with one? Bit long winded but any help would be much appreciated cheers.
Post #558357 20th Jun 2020 2:44pm
Jri711
Just another update, turns out it was the height sensor & not a wiring fault, so you can have a active dynamics fault from the sensor while your ride height will work just fine. This is what through me plus what most people’s faults were with the wiring.
Post #558477 21st Jun 2020 4:04pm
Glad you got it sorted, thanks for letting us know what it was... Thumbs Up Pete
Post #558484 21st Jun 2020 4:16pm
Discotigger
Think I've got the same problem, got a new height sensor and getting my Indy guy to fit it this week, along with replacing the gaskets and o-rings on the oil cooler as I've got the dreaded Oil Cooler leak.
Had checked the wires in the car and around the sensor and couldn't see any breaks, so hopefully a new sensor will sort the fault.
Post #558495 21st Jun 2020 5:14pm
Discotigger
Just to answer your question, pins 1, 4 & 5 are for the Air Suspension; pins 2, 3 & 6 are for the Adaptive Dynamics Thumbs Up
Post #558507 21st Jun 2020 7:31pm
Jri711
Yeah sussed that now, least next time it’ll make diagnoses easier
Post #558528 21st Jun 2020 9:01pm
