![]() | Home > Technical (L322) > Adaptive dynamics but not the front ! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3825 ![]() ![]() ![]() |
Previous fault reports have shown they break very near the top of the strut very similar to the fronts, but much less common.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 22 ![]() ![]() ![]() |
Cheers guys, least I know where to look now, I’ll get a sensor and fit that the same time. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I remember another member had a chaff where the loom came through the body too... Cheers, Greg
Checked all these parts of the wiring, & all seams ok but like I said I’ll run a loom check next time I get a chance, but what do you guys think about the level sensor? I mean what’s the odds on just the dynamics side going down as the ride heights all change up & down fine. |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
That was the issue on mine, chafed wires on the offside rear height sensor, but the ride height functionality worked fine. 2011 TDV8 4.4 AB Bournville Brown |
Jri711 if you have an IID it will tell you which side too....
Ok, had a bit of a look today, from my left rear sensor it seams I have Continuity On pins 2 ,6 & 3 nothing on 1 ,4 & 5 I’ve also done the same test once the loom is inside the car under the rear seats/carpet with the same results, my questions are do all the wires from the sensor go to the ADM ? If not where do they or if so can anyone tell me which pins do 1,4 & 5 go to because I can’t seam to be able to distinguish the colours on the ADM ? If this is a break in the loom where the hell else would you look? There’s no damage anywhere I’ve looked on the loom. If they do go else where & the loom turn out to be ok what’s the chances of a height sensor going down on just the ADM side & has anyone else had that fault with one? Bit long winded but any help would be much appreciated cheers. |
Just another update, turns out it was the height sensor & not a wiring fault, so you can have a active dynamics fault from the sensor while your ride height will work just fine. This is what through me plus what most people’s faults were with the wiring. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8562 ![]() ![]() ![]() |
Glad you got it sorted, thanks for letting us know what it was... |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Think I've got the same problem, got a new height sensor and getting my Indy guy to fit it this week, along with replacing the gaskets and o-rings on the oil cooler as I've got the dreaded Oil Cooler leak.
Just to answer your question, pins 1, 4 & 5 are for the Air Suspension; pins 2, 3 & 6 are for the Adaptive Dynamics ![]() |
Yeah sussed that now, least next time it’ll make diagnoses easier |
