Aspirator motor fault Heater Matrix | |
I am getting this fault using my IID tool
ATC-Heat / Cool aka HVAC
0x2F Aspirator motor fault
have done some searching, but still a bit confused, apparently there is something called an "Aspirator Motor" behind the HVAC control panel inside the car, this motor spins to draw air in to measure the ambient temp, so if this sticks or fails to read the outside temperature readings an error occurs ie Aspirator Motor Fault
The motor sits somewhere inside the AC Heater Blower housing, can someone confirm
