Home > Technical (L322) > Humming/rumble/droning/vibration at low speeds
jackie-o
Netherlands
Here we go again....
So after having had the car back from major surgery for about 4 weeks, I am now getting a humming/droning/vibration at low speeds. It is not always there but more increasingly so.
The sound comes as I lift off the throttle at low speeds. I did have it once at higher speed (60mph-ish) and it was a constant humming and clearly audible. I pulled over, turned the engine off and the sound went away.
The car has brand new tyres and its had a four wheel alignment done by LR.
I had a wheel baring changed on my Disco 4 which was a similar sound/feel but my indy says it´s rare for these to fail on the L322s.
The car has done about 78k miles, Any ideas what this can be? RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #557526 13th Jun 2020 9:57am
Brian Considine
Did you have the sound before the new tyres were fitted ? 2003 Range Rover Vogue TD6
Post #557544 13th Jun 2020 12:00pm
jackie-o
Netherlands
I dont think so.
Also didn’t have it in the first couple of weeks or so after getting it back from the garage.
Its come in the last two weeks and increased last few days....
I’ve driven it approx 900 miles since fitting new tyres and having the wheel alignment done RR Vogue 4.4 TDV8 - 11
Post #557546 13th Jun 2020 12:39pm
jackie-o
Netherlands
Anyone got any ideas what this can be? It´s starting to drive me nuts....
Most prevalent around 25 mph and revs at 1.000 rpm
Wheel barings have been tested and eliminated.... RR Vogue 4.4 TDV8 - 11
Post #558486 21st Jun 2020 4:21pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I had a humming/resonance noise that was quite a deep sound. Had it on a ramp Friday and held it at 1000-1100rpm where it was worse. Mechanic said it was the heat shield on the bottom of the gearbox.
He did a bit of adjustment and now silent. He also crimped up a cat shield as well that was loose but that was not the cause of the noise. 2011 4.4tdv8 Vogue
Baltic Blue
Post #558489 21st Jun 2020 4:39pm
jackie-o
Netherlands
I had the gearbox done about 3,000 miles ago, both oil and filter - perhaps something has come undone?
Will get it on a ramp tomorrow and check.
Thanks! RR Vogue 4.4 TDV8 - 11
Post #558497 21st Jun 2020 5:42pm
Gazcw
Could be a bent or loose heat shield. Worth a check before spending money. 2011 4.4tdv8 Vogue
Baltic Blue
Post #558505 21st Jun 2020 6:49pm
jackie-o
Netherlands
So finally got the car on a lift and indeed several heat shields and other bits were loose. Indy tightened everything he could find bu the humming is still there....
Only appears at 1.000 rpm and most audible as revs drop but I now have it every time and its annoying.
Any other ideas what it could be? RR Vogue 4.4 TDV8 - 11
Post #560633 8th Jul 2020 1:42pm
jackie-o
Netherlands
Thanks for the suggestion Mark but the problem is it only comes under load. Even with the car in drive and breaking with my left foot its hard to replicate using the throttle. But as soon as the car is moving its there.... RR Vogue 4.4 TDV8 - 11
Post #560844 9th Jul 2020 10:30pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Don't discount wheel bearings if the sound is only present whilst moving. I had a front left go and I think I am starting to hear a rumble from the front right. Mine have done around 100k miles. Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #560875 10th Jul 2020 8:22am
jackie-o
Netherlands
Hi Rob,
We discounted it only because my indy test drove the car, chucked it pretty hard from side to side and we got nothing out of it.
My biggest concern is that it is something gearbox or engine related? RR Vogue 4.4 TDV8 - 11
Post #561372 14th Jul 2020 9:43am
Funnily enough, my car has started to make a similar noise too. I only noticed it a week or so ago when pulling away from the lights. If I take my foot off the accelerator and coast, it disappears but when I reapply power, I hear it.
My initial thoughts were wheel bearings, but since it’s not there all the time, I can’t see how it could be that.
I just hope it’s not something in the drivetrain that’s staring to get tired Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #561380 14th Jul 2020 10:28am
cubbyno9
United Kingdom 2013 Range Rover Vogue SE SDV8 Farallon Black
Hi, did you get to bottom of the noise.
I have a noise when at low speed, accelerate and it’s fine but when I lift off throttle i have this winning, whizzing, almost rattle sound.
It drives and changes gear fine, no juddering. I initially thought something like a heat shield or such like vibration, but worried its gearbox.
Thanks.
Post #692027 6th May 2024 7:48pm
jackie-o
Netherlands
In my case it was rattling heat shields so turned out to be an easy fix. Hope the same for you! RR Vogue 4.4 TDV8 - 11
Post #692028 6th May 2024 8:42pm
cubbyno9
Hi, thanks for reply.
Yes I hope it is. Definitely sounds like it.
Post #692030 6th May 2024 9:11pm
