![]() | Home > Technical (L322) > Humming/rumble/droning/vibration at low speeds |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Did you have the sound before the new tyres were fitted ? 2003 Range Rover Vogue TD6 |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
I dont think so.
Anyone got any ideas what this can be? It´s starting to drive me nuts....
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
I had a humming/resonance noise that was quite a deep sound. Had it on a ramp Friday and held it at 1000-1100rpm where it was worse. Mechanic said it was the heat shield on the bottom of the gearbox.
I had the gearbox done about 3,000 miles ago, both oil and filter - perhaps something has come undone?
Could be a bent or loose heat shield. Worth a check before spending money. 2011 4.4tdv8 Vogue
So finally got the car on a lift and indeed several heat shields and other bits were loose. Indy tightened everything he could find bu the humming is still there....
Thanks for the suggestion Mark but the problem is it only comes under load. Even with the car in drive and breaking with my left foot its hard to replicate using the throttle. But as soon as the car is moving its there.... RR Vogue 4.4 TDV8 - 11
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
Don't discount wheel bearings if the sound is only present whilst moving. I had a front left go and I think I am starting to hear a rumble from the front right. Mine have done around 100k miles. Rob 05 L322 4.2SC
Hi Rob,
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6777 ![]() ![]() ![]() |
Funnily enough, my car has started to make a similar noise too. I only noticed it a week or so ago when pulling away from the lights. If I take my foot off the accelerator and coast, it disappears but when I reapply power, I hear it.
cubbyno9 Member Since: 05 Mar 2013 Location: Glasgow Posts: 10 ![]() ![]() ![]() |
Hi, did you get to bottom of the noise.
In my case it was rattling heat shields so turned out to be an easy fix. Hope the same for you! RR Vogue 4.4 TDV8 - 11
Hi, thanks for reply.
