Home > Technical (L322) > Humming/rumble/droning/vibration at low speeds |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Did you have the sound before the new tyres were fitted ? 2003 Range Rover Vogue TD6 |
13th Jun 2020 11:00am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
I dont think so.
13th Jun 2020 11:39am |
Anyone got any ideas what this can be? It´s starting to drive me nuts....
21st Jun 2020 3:21pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
I had a humming/resonance noise that was quite a deep sound. Had it on a ramp Friday and held it at 1000-1100rpm where it was worse. Mechanic said it was the heat shield on the bottom of the gearbox.
21st Jun 2020 3:39pm |
I had the gearbox done about 3,000 miles ago, both oil and filter - perhaps something has come undone?
21st Jun 2020 4:42pm |
Could be a bent or loose heat shield. Worth a check before spending money. 2011 4.4tdv8 Vogue
21st Jun 2020 5:49pm |
So finally got the car on a lift and indeed several heat shields and other bits were loose. Indy tightened everything he could find bu the humming is still there....
8th Jul 2020 12:42pm |
Thanks for the suggestion Mark but the problem is it only comes under load. Even with the car in drive and breaking with my left foot its hard to replicate using the throttle. But as soon as the car is moving its there.... RR Vogue 4.4 TDV8 - 11
9th Jul 2020 9:30pm |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
Don't discount wheel bearings if the sound is only present whilst moving. I had a front left go and I think I am starting to hear a rumble from the front right. Mine have done around 100k miles. Rob 05 L322 4.2SC
10th Jul 2020 7:22am |
Hi Rob,
14th Jul 2020 8:43am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6731 |
Funnily enough, my car has started to make a similar noise too. I only noticed it a week or so ago when pulling away from the lights. If I take my foot off the accelerator and coast, it disappears but when I reapply power, I hear it.
14th Jul 2020 9:28am |
cubbyno9 Member Since: 05 Mar 2013 Location: Glasgow Posts: 10 |
Hi, did you get to bottom of the noise.
6th May 2024 6:48pm |
In my case it was rattling heat shields so turned out to be an easy fix. Hope the same for you! RR Vogue 4.4 TDV8 - 11
6th May 2024 7:42pm |
Hi, thanks for reply.
6th May 2024 8:11pm |
