Home > Maintenance & Mods (L322) > 2011 battery choices AGM 019 ?
Page 3 of 3 <123
Baltic Blue
Sorry Landmark but I disagree…and so do JLR.
2010/2011’s were originally fitted with standard 019 type batteries but very soon all recalled to upgrade to AGM type because of the number of problems.
Post #604731 25th Aug 2021 9:27am
DrRob
Fit an AGM. As above, LR soon regretted fitting non-AGM and swapped them out. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #604748 25th Aug 2021 3:45pm
mjdronfield
My old one is AGM I believe…. The one I picked up from JLR last week definitely is.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #604751 25th Aug 2021 4:32pm
jackie-o
Netherlands
So our car was more or less dead this morning, I’m hoping its the battery.
Do I understand it correct that if I change it to a new non-agm then its just a straight swap but if I upgrade to an AGM then it also needs a software update/setting?
Can any garage do this or do i need to go to LR?
My indy is closed today and I deperatly need the car for monday morning..... RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #604922 27th Aug 2021 10:12am
DrRob
Do it yourself. You don't even need the special torx if you remove the whole bracket via the 10mm nut. Read the whole of this topic: https://www.fullfatrr.com/forum/topic43662.html
Don't worry about the BMS reset for Monday. Most folks don't do it and the car is usually fine.
Fit an AGM if you can but in an emergency then personally I wouldn't be too worried. LR fitted them from new before moving to AGM Whistle
So - go to the battery shop, get an AGM if you can and then fit yourself. It will be cheaper and quicker. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #604923 27th Aug 2021 10:41am
DrRob
Dean_C wrote:
Fitted a Halfords branding battery 019 agm with a five year warranty.
“Halfords 019AGM Start/Stop AGM 12V Car Battery 5 Year Guarantee 548653”
Seems to do the job fine, only thing I need to set the computer/ ecu to new agm type battery.
How's that battery fairing Dean? I now have a Halfords Trade Card Whistle Thumbs Up
https://www.halfords.com/motoring/batterie...48653.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #604925 27th Aug 2021 10:51am
jackie-o
Netherlands
Thanks Rob, AGM it is then I supose!
//J RR Vogue 4.4 TDV8 - 11
Post #604949 27th Aug 2021 1:52pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
I recently got a Bosch S5 AGM 019 (I think Bosch call them 013) for £152 delivered from EBay.
Post #604981 27th Aug 2021 7:18pm
jackie-o
Netherlands
Went for a Varta Silver G14 AGM, 12 V, 950 ah, 850 cca.
No idea what this means but seems to match up with what others have posted.
Equivelant of 295 gbp in Sweden, great country....
My indy recomended Varta over Exide for whatever reason. RR Vogue 4.4 TDV8 - 11
Post #605017 28th Aug 2021 9:26am
Page 3 of 3 <123
