Home > Maintenance & Mods (L405) > dynamic mirror indicators
Page 2 of 10 <12345678910>
dunno Alistair...these are 'E' marked so does that make them ok?
and that very small illuminated bit on the OE light, does it really make a difference in the real world... ... - .- -.
Post #553844 14th May 2020 10:03am
I tell mine everything just in case - I get charged an extra premium for having genuine 22's from the same MY but not factory fitted - it's 20's on the build sheet and I don't want to run the risk of a claim being rejected.
Once you're into the realm of what might potentially constitute a safety feature, things get a bit grey.....
Post #553851 14th May 2020 10:57am
i see what Craig is referring to now....put the hazards on and from the front you cant see much of the light and stood at the back you see a small orange bit right on the tip of the mirror housing..
so with the dynamic indicators you wont seen that but the side/front will be more visible... ... - .- -.
Post #553893 14th May 2020 4:28pm
Brian Considine
The C & U Regs must have been changed because at one time all indicators had to flash in unison with one another.
They must also have changed regarding foglights being used as cornering lights because at one time auxiliary lights had to be mounted & used in pairs. 2003 Range Rover Vogue TD6
Post #553933 15th May 2020 8:02am
any news on yours yet Horse? ... - .- -.
Post #554717 21st May 2020 9:57am
Ive had the same thought as you Brian when i purchased our latest Ford Connect... The front fogs are the cornering lamps! Not twin bulbs as i was expecting...
Post #554720 21st May 2020 10:19am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
nothing yet 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #554766 21st May 2020 3:33pm
Cagonline
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Hello everybody,
This is my first post. In response to the “sweeping” indicators from PowerfulUK, I have fitted them to my car. I think they do add a certain style and I don’t think they represent a danger in their operation.
I’ve enclosed a couple of photos with them on the car, although it’s a photo and it’s not representative of their functionality.
Regards,
Peter
Post #554789 21st May 2020 7:23pm
hi Peter and welcome to the forum..so you think they are worth he cost? are they significantly brighter?
and what about the question of 'can they be seen from the rear'.. ... - .- -.
Post #554798 21st May 2020 8:26pm
Cagonline
Hello Stan,
Thank you for your welcome. Personally, I bought them on a style basis, and on that factor I am pleased with them. Regarding whether they are visible from the rear, I would say that they aren’t as visible as the originals. However, does that really matter? If your spatial awareness is good, then I don’t consider that to be much of an issue. If your attention has lapsed momentarily, and an approaching vehicle could misinterpret your actions, then yes these could be deemed as less satisfactory. But there are other safety aids to warm you of a potential situation anyway.
So for me, and we are all different, it was merely an aesthetic purchase decision.
Peter
Post #554806 21st May 2020 8:54pm
thanks Peter..
i think the dynamic ones would be more noticeable from the side and front , ie at junctions for instance..
must order some before i change my mind.. ... - .- -.
Post #554996 23rd May 2020 11:49am
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Stan, I fitted a pair of these this morning and no, they aren't as visible from the rear, but you're right, they are more visible from other angles. On balance, I'd say they're a good mod and had Craig not mentioned the view from the rear, I doubt I'd have noticed. He does of course have a point though.
Post #555001 23rd May 2020 12:13pm
so do you recommend them Rob? ... - .- -.
Post #555003 23rd May 2020 12:22pm
roberlar
Yes, on the whole very pleased and they seem well made. Just be aware you need to push the connector in the opposite way to originals for some reason and the mirror casings in my case were a bit of a Censored to remove.
Post #555006 23rd May 2020 12:45pm
thanks for the tip Rob...
in the powerfuluk video they said to check the indicators worked before putting the covers back on cos theirs didnt at first obviously because of the reversed plug. .. ... - .- -.
Post #555015 23rd May 2020 2:16pm
