Home > Maintenance & Mods (L322) > Transfer Box Fluid
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Transfer Box Fluid
Looking forwards a couple of weeks or so, I want to do oil and fluid changes on the diffs and transfer box.
Diff oil is no problem but I am struggling to find the transfer box fluid Shell TF 0753, all I can find is one by Smith and Allen on eBay at £17 a litre.
I have never heard of Smith and Allen has anyone else? or are there other known alternatives that you recommend?
Normally I would insist on Shell as its the only one LR specify so at the moment I will have to wait for the main dealer to reopen.
Thanks Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #553366 10th May 2020 5:37pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Try Opie Oils
Jim
Post #553373 10th May 2020 6:22pm
DrRob
Advanced Factors do the right oil grade to spec. Plus a generous discount at the moment. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553374 10th May 2020 6:28pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
I have used Smith and Allen ATF in a previous vehicle and had no problems.
Also I think Duckworths can supply the genuine fluid and are still shipping. 2008/58 FFRR 3.6 TDV8 Vogue
Post #553393 10th May 2020 9:18pm
bigbo
Thanks all.
Opie don't list it on their site
Advanced Factors have LR branded but by the time you add postage it's £36, I just thought that a bit much
Done some research on Smith and Allen, they sound like a very good company and seem to be trusted on other forums as well so that's an option.
Why I didn't think of asking Duckworth's I have no idea! I have an outstanding query with Rob so will add this on.
Again thanks. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553402 10th May 2020 10:45pm
RRPhil
The Shell fluid was developed to give the right static-to-dynamic friction characteristics for the torque-biasing and differential-locking clutch in the DD295. The range change synchronisers are also calibrated around this fluid’s friction qualities. Unless you’re absolutely sure that a replacement fluid has identical friction modifiers in it, you should stick with TF 0753 or you could seriously mess up the calibration. In my opinion your transfer box is better off with old correct fluid in it than new incorrect fluid. Although the correct fluid is ridiculously expensive, you only need 1.5 litres of it.
Phil
Post #553406 11th May 2020 12:30am
bigbo
Phil
Thanks your knowledge is legendary on this forum, however I thought only on auto gearboxes, but of course this is a gearbox we are talking about, so I appreciate your input.
OK, that's set me straight I will buy either the Shell or LR fluid (I assume they are the same), I do not want to compromise on such an expensive component.
Regards
David
PS Love the pictures.... Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553407 11th May 2020 12:41am
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Wrong thread
Post #553421 11th May 2020 8:56am
jim4244
https://rimmerbros.com/Item--i-STC4861?gcl...gI-kfD_BwE
Post #553422 11th May 2020 9:15am
RRPhil
Just to be sure that there’s no confusion here.
If you have a 5-speed transmission (ZF 5HP24 or GM 5L40-E) you have the New Venture Gear NV225 transfer box.
If you have a 6- or 8-speed transmission (ZF 6HP26/28 or ZF 8HP70) you have the Magna Steyr DD295 transfer box.
The two transfer boxes require different fluids.
For the earlier unit (NV225) the fluid friction characteristics have to satisfy the requirements of the Torsen Type-B centre differential and the range-change synchroniser cones – hence you should only use Castrol BOT 26 FMB 1 75W-90 (1 litre capacity).
For the later transfer box (DD295) the friction modifiers in the fluid have to match the requirements of the multi-plate clutch, which performs the front-to-rear torque biasing & centre diff. lock, and the range-change synchroniser cones – hence you should only use Shell TF 0753 (1.5 litre capacity).
Phil
Post #553425 11th May 2020 9:39am
bigbo
Thanks Phil
Clearly put, I was about to post that the Rimmer Brothers one was incorrect for my car. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553427 11th May 2020 10:04am
jim4244
Sorry. For some reason I thought you had a TD6 with the 5 speed GM box and transfer box.
Jim
Post #553428 11th May 2020 10:33am
kevinp
[quote="RRPhil"]Just to be sure that there’s no confusion here.
Hi Phil, I've been looking for ages for Shell TF 0753 and still confused because searches for that grade come back with TF 0870 by the likes of rimmer bros etc.
Post #554956 23rd May 2020 6:31am
kevinp
I've just ordered transfer box oil and axle oils off Rimmer bros after a chat on the phone. Genuine land rover tf0753 and castrol SAF-XO. Expensive but a bit paranoid about what others have been using and somewhat conflicting advice.
Post #554973 23rd May 2020 8:53am
bigbo
I should have posted that I ordered some from Duckworths for a good price.
Just got to get it done now.
I agree its right to be wary its an expensive component to replace if it goes wrong. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #555009 23rd May 2020 1:10pm
