![]() | Home > Maintenance & Mods (L322) > Transfer Box Fluid |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Try Opie Oils
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4312 ![]() ![]() ![]() |
Advanced Factors do the right oil grade to spec. Plus a generous discount at the moment. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
I have used Smith and Allen ATF in a previous vehicle and had no problems.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Thanks all.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 ![]() ![]() |
The Shell fluid was developed to give the right static-to-dynamic friction characteristics for the torque-biasing and differential-locking clutch in the DD295. The range change synchronisers are also calibrated around this fluid’s friction qualities. Unless you’re absolutely sure that a replacement fluid has identical friction modifiers in it, you should stick with TF 0753 or you could seriously mess up the calibration. In my opinion your transfer box is better off with old correct fluid in it than new incorrect fluid. Although the correct fluid is ridiculously expensive, you only need 1.5 litres of it.
Phil
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 ![]() ![]() ![]() |
Wrong thread |
Just to be sure that there’s no confusion here.
Thanks Phil
Sorry. For some reason I thought you had a TD6 with the 5 speed GM box and transfer box.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 ![]() ![]() ![]() |
[quote="RRPhil"]Just to be sure that there’s no confusion here.
I've just ordered transfer box oil and axle oils off Rimmer bros after a chat on the phone. Genuine land rover tf0753 and castrol SAF-XO. Expensive but a bit paranoid about what others have been using and somewhat conflicting advice. |
I should have posted that I ordered some from Duckworths for a good price.
