Home > Maintenance & Mods (L322) > Transfer Box Fluid |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Try Opie Oils
10th May 2020 6:22pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4312 |
Advanced Factors do the right oil grade to spec. Plus a generous discount at the moment. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th May 2020 6:28pm |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 |
I have used Smith and Allen ATF in a previous vehicle and had no problems.
10th May 2020 9:18pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 |
Thanks all.
10th May 2020 10:45pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 |
The Shell fluid was developed to give the right static-to-dynamic friction characteristics for the torque-biasing and differential-locking clutch in the DD295. The range change synchronisers are also calibrated around this fluid’s friction qualities. Unless you’re absolutely sure that a replacement fluid has identical friction modifiers in it, you should stick with TF 0753 or you could seriously mess up the calibration. In my opinion your transfer box is better off with old correct fluid in it than new incorrect fluid. Although the correct fluid is ridiculously expensive, you only need 1.5 litres of it.
11th May 2020 12:30am |
Phil
11th May 2020 12:41am |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
Wrong thread |
11th May 2020 8:56am |
11th May 2020 9:15am |
Just to be sure that there’s no confusion here.
11th May 2020 9:39am |
Thanks Phil
11th May 2020 10:04am |
Sorry. For some reason I thought you had a TD6 with the 5 speed GM box and transfer box.
11th May 2020 10:33am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 |
[quote="RRPhil"]Just to be sure that there’s no confusion here.
23rd May 2020 6:31am |
I've just ordered transfer box oil and axle oils off Rimmer bros after a chat on the phone. Genuine land rover tf0753 and castrol SAF-XO. Expensive but a bit paranoid about what others have been using and somewhat conflicting advice. |
23rd May 2020 8:53am |
I should have posted that I ordered some from Duckworths for a good price.
23rd May 2020 1:10pm |
