![]() | Home > Technical (L322) > 4.4 TDV8 Throttle Body |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Thanks š Does the car need ātellingā it has a new one fitted? No fault codes before fitting or after. Test drive tomorrow am. I changed it as my old one was getting a little sooty underneath on outside. Some have tried ptfe tape but I thought ![]() Iām all about preventative maintenance ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
Yes. The MAF sensor is at the air-box. |
Thanks. I checked with an LR ex mechanic and he confirms itās a sensor to monitor boost temperature. If it goes up too high a value then boost is backed off |
Sorry, he also said no IID coding needed etc.
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
Has the airflow temp sensor got any maker or spec markings on it?
Iāll take a look at the old one and let you know |
Ok. The alternative is to cut the spring section off, leave the sensor in and use a piece of silicon pipe between the two.
Good idea too |
No I haven't but I am in need of a new one I think as my soot levels are climbing too quickly.
I'd be tempted to buy a new one off Duckworths (quick delivery by Robin I might add) and then you have your old one to play around with an alternative solution. I think the easiest way will be to cut off the end with the seal/clip thus leaving the plastic pipe with sensor and "side pipe" intact and then find a wide bore silicone hose to bridge to the throttle body. There is a fair length of throttle body "metal" for it to cover too....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
5 regens is a lot
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 ![]() ![]() ![]() |
Does anyone know the part number for the delicate water connection - Iāve just broken mine and need to get a replacement, canāt see it on the advanced factors site Cheers |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Replied to your other post |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 777 ![]() ![]() ![]() |
LR029140 ![]() ![]() |
