Home > Technical (L405) > Low battery warning but which battery?
Baltic Blue
If you have got an iid ...check the battery State of charge... should be over 82%
Post #550123 12th Apr 2020 5:27pm
ur20v
A Trap
Fleagle_UK wrote:
Thanks.
My post really was more about questioning the cars system of operation rather than how to manually test batteries.
Thanks again.
I think you need to crack out the multimeter and check your battery voltages.... just saying.
Post #550124 12th Apr 2020 5:27pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Agree totally, I relied on the dash info, fitted a new primary battery, message still appearing, fitted a new aux battery, message still appearing. Both batteries I replaced are in good order. The most annoying thing is the car seems to cut out non essential functions such as FBH on the basis it believes the Battery(s) are low, which in my case they weren't. On my 2013 AB the main battery is over 800 CCA and the aux battery is over 700 CCA. That's a lot of juice for one vehicle. I should also add that the original battery on my L322 which I bought new lasted 12 years and as far as I'm aware didn't have this unnecessary feature. It's fairly obvious when you need a new battery.
Post #550129 12th Apr 2020 6:02pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Craig. Charger charges battery to around 90-95% (itakes quite a while to get there) then switches to trickle charge mode.
Around 24-36 hours later of the car not being moved, I will get the low battery warning when I get in the car. Clearly a number of systems are waking up plus I have deployable side steps and the BMS isn’t happy at the state of the battery.
To be honest over all the Landrover’s I’ve had, 3 Years is about average life span I have had for an AGM battery. They don’t last as long as good old traditional ones.
I do have an IID tool but does that show me separately voltages of the two batteries just a combined overall reading? Or just the main battery?
I’m sure I read somewhere once (doesn’t means it’s true of course) that manually charging a battery can throw the BMS. Ie somehow if the voltage it sees don’t tally with what it’s “memory” thought you last had (i.e from when the cars alternator last generated its own charge over time), then it has a wobbly.
Post #550172 13th Apr 2020 10:30am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Fleagle I've just replaced the original battery in my 2015 RR AB. I ordered a new genuine one from Midland Car Spares via "The Bay" at a very competitive price. Wink It arrived in two days and has solved all the same issues you are experiencing. Thumbs Up
`I was so pleased I ordered another for SWMBO's D4 as her car was starting to suffer the same low battery warning and wouldn't seem to hold a charge. Original battery and again a two day delivery, problem solved and even the stop start has started working again and thats been "foobarred" for 3 years! And there's me thinking I might save some money being stuck at home:lol:
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #550521 16th Apr 2020 3:17pm
ianjb1970
United Kingdom 2015 Range Rover Vogue SE SDV8 Fuji White
Low voltage
Chaps,
Battery doesn’t seem too good on my 2015 4.4 v8 it only just started the car, I got a low power warning, charged car via pins under bonnet, looking for advice where to get a battery & will the car need re program? I checked voltage at under bonnet pins 12.8 but car still telling me low voltage. Any help much appreciated
Post #554127 16th May 2020 9:38pm
dolph34
EK1050 4 Year Warranty Exide AGM Start Stop Battery 105AH 950CCA 020AGM
1x Exide Stop Start 70Ah 760CCA 12v 067 AGM Car Battery 4 Year Warranty - EK700
I believe these are the two batteries but thats only my limited understanding Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #554129 16th May 2020 9:40pm
