![]() | Home > Technical (L405) > Low battery warning but which battery? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
If you have got an iid ...check the battery State of charge... should be over 82%
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Agree totally, I relied on the dash info, fitted a new primary battery, message still appearing, fitted a new aux battery, message still appearing. Both batteries I replaced are in good order. The most annoying thing is the car seems to cut out non essential functions such as FBH on the basis it believes the Battery(s) are low, which in my case they weren't. On my 2013 AB the main battery is over 800 CCA and the aux battery is over 700 CCA. That's a lot of juice for one vehicle. I should also add that the original battery on my L322 which I bought new lasted 12 years and as far as I'm aware didn't have this unnecessary feature. It's fairly obvious when you need a new battery. |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Craig. Charger charges battery to around 90-95% (itakes quite a while to get there) then switches to trickle charge mode.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Fleagle I've just replaced the original battery in my 2015 RR AB. I ordered a new genuine one from Midland Car Spares via "The Bay" at a very competitive price. |
ianjb1970 Member Since: 07 Nov 2016 Location: Gloustershire Posts: 4 ![]() ![]() ![]() |
Chaps,
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
EK1050 4 Year Warranty Exide AGM Start Stop Battery 105AH 950CCA 020AGM
