![]() | Home > In Car Electronics (L322) > Ulf Range Rover Bluetooth upgrade |
Lee1974 Member Since: 09 Apr 2020 Location: West midlands Posts: 17 ![]() ![]() ![]() |
I will eventually fit a switch is That easy cus I’m always changing my phones lol |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
I just put it on the wires in the boot, then tucked it away....nothing fancy. 2011 Range Rover Vogue SE 4.4 TDV8
I didn’t have that issue....can only suggest checking wiring. Take it you have not got the pins shorted now.....
Yes all paired and can go through contacts aswell just can’t hear anything pins shorted fine m8
Think pin 51 is the mute signal.
Can’t hear nothing at all so don’t now wen connected all the wires seem mixed up the red wire not attached or yellow or pin 51 |
The cable that was on pin 29 should now be in 51.
I apreshiate you help I’m goin off the colours on a listing
I’m not sure, it’s not my chart. I just moved the cables from pin to pin without looking at colours.
Looks like that’s correct....
Thanks for that info I’ll have another look tomoz got all working with radio mute and I can hear people but they can’t hear me so just the mic to sort out lol |
Getting there mate. There aren’t really that many wires that it actually uses. 2011 Range Rover Vogue SE 4.4 TDV8
