Home > In Car Electronics (L322) > Ulf Range Rover Bluetooth upgrade
Lee1974
England 2002 Range Rover Vogue 4.4 V8 Java Black
I will eventually fit a switch is That easy cus I’m always changing my phones lol
Post #549807 9th Apr 2020 8:37pm
mjdronfield
I just put it on the wires in the boot, then tucked it away....nothing fancy. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #549808 9th Apr 2020 8:51pm
Lee1974
Hi m8 thanks for help got phone connected no problem with shorting pins great
But wen make a call radio stays on and can’t hear anything from phone
Post #549874 10th Apr 2020 3:05pm
mjdronfield
I didn’t have that issue....can only suggest checking wiring. Take it you have not got the pins shorted now.....
Has it paired properly? Is the Land Rover listed on your phone? Can you go through your contacts using the steering wheel buttons?
Just trying to see if the issue is pairing with phone....rather than a wiring issue.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549876 10th Apr 2020 3:29pm
Lee1974
Yes all paired and can go through contacts aswell just can’t hear anything pins shorted fine m8
But the wires seem to be different colours to your diagram I did not to the pin swop see
Post #549877 10th Apr 2020 3:32pm
mjdronfield
Think pin 51 is the mute signal.
Can people hear you or is it just you can’t hear them?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549878 10th Apr 2020 3:38pm
Lee1974
Can’t hear nothing at all so don’t now wen connected all the wires seem mixed up the red wire not attached or yellow or pin 51
Post #549879 10th Apr 2020 3:42pm
mjdronfield
The cable that was on pin 29 should now be in 51.
Can’t check anything I’m afraid as I sold the car in 2015.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549880 10th Apr 2020 3:50pm
Lee1974
I apreshiate you help I’m goin off the colours on a listing
We’re it says cab 29 white/brown but then says yellow side off it what’s that mean
Post #549881 10th Apr 2020 3:55pm
mjdronfield
I’m not sure, it’s not my chart. I just moved the cables from pin to pin without looking at colours.
That said, I seem to remember the wire on 32 being white, so using the notes for that on the scribbles, the colours under the CAB bit are maybe what they should be now...if you see what I mean. So wire in 51 should be white/brown?
On the edge of guessing now.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549886 10th Apr 2020 4:13pm
mjdronfield
Looks like that’s correct....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549889 10th Apr 2020 4:17pm
Lee1974
Thanks for that info I’ll have another look tomoz got all working with radio mute and I can hear people but they can’t hear me so just the mic to sort out lol
Post #549899 10th Apr 2020 4:54pm
mjdronfield
Getting there mate. There aren’t really that many wires that it actually uses. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #549902 10th Apr 2020 5:42pm
