Home > Maintenance & Mods (L322) > 2011 4.4 Tdv8 belt running off help!!!! |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Replaced with genuine parts? |
18th Mar 2020 9:27pm |
Southeast Member Since: 18 Mar 2020 Location: South Posts: 9 |
Yes including belt |
18th Mar 2020 9:31pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
DIY ?
18th Mar 2020 10:03pm |
No mechanic has anyone experienced this issue? And have they cured it? |
18th Mar 2020 10:08pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2495 |
How much is the crankshaft pulley dancing around? The rubber inserts in damper pulleys (not specifically the 4.4's) can deteriorate. |
18th Mar 2020 10:19pm |
Doesn't seem to be much movement but I'll check again as I wasnt aware there was an issue with them thanks |
18th Mar 2020 10:22pm |
Did it cure it? |
18th Mar 2020 10:53pm |
Have you worked from the workshop manual?
18th Mar 2020 10:54pm |
No might have a look |
18th Mar 2020 11:01pm |
kit includes....
19th Mar 2020 7:59am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
What was the problem that Craig highlighted years ago that causes the edge of the belt to rub , chaff and fail?
19th Mar 2020 8:20am |
That would be a super help thanks |
19th Mar 2020 9:39am |
The common problem is due to a worn tensioner and yours has since been replaced. |
19th Mar 2020 10:26am |
Exactly just thought someone might have found a different issue . hopefully !! |
19th Mar 2020 10:31am |
