![]() | Home > Maintenance & Mods (L322) > 2011 4.4 Tdv8 belt running off help!!!! |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Replaced with genuine parts? |
Southeast Member Since: 18 Mar 2020 Location: South Posts: 9 ![]() ![]() ![]() |
Yes including belt |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
DIY ?
No mechanic has anyone experienced this issue? And have they cured it? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
How much is the crankshaft pulley dancing around? The rubber inserts in damper pulleys (not specifically the 4.4's) can deteriorate. |
Doesn't seem to be much movement but I'll check again as I wasnt aware there was an issue with them thanks |
Did it cure it? |
Have you worked from the workshop manual?
No might have a look |
kit includes....
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
What was the problem that Craig highlighted years ago that causes the edge of the belt to rub , chaff and fail?
That would be a super help thanks |
The common problem is due to a worn tensioner and yours has since been replaced. |
Exactly just thought someone might have found a different issue . hopefully !! |
