Home > Maintenance & Mods (L322) > 2011 4.4 Tdv8 belt running off help!!!!
Southeast
Ireland 2011 Range Rover Vogue SE TDV8 Stornoway Grey
Hi all I'm at my wits end trying to get to bottom of problem (3 belts later) the aux belt is running off line from the tensioner pulley to the next idler pulley running out about 5 mm when running and moving back in when switched off I have replaced all pulleys, tensioner and belt and no change !! Please any suggestions??
Post #547543 18th Mar 2020 8:57pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Replaced with genuine parts?
Post #547545 18th Mar 2020 9:27pm
Southeast
Yes including belt
Post #547546 18th Mar 2020 9:31pm
GGDR
DIY ?
. Cheers, Greg
Post #547550 18th Mar 2020 10:03pm
Southeast
No mechanic has anyone experienced this issue? And have they cured it?
Post #547551 18th Mar 2020 10:08pm
GraemeS
How much is the crankshaft pulley dancing around? The rubber inserts in damper pulleys (not specifically the 4.4's) can deteriorate.
Post #547552 18th Mar 2020 10:19pm
Southeast
Doesn't seem to be much movement but I'll check again as I wasnt aware there was an issue with them thanks
Post #547553 18th Mar 2020 10:22pm
Southeast
Did it cure it?
Post #547557 18th Mar 2020 10:53pm
GGDR
Have you worked from the workshop manual?
I haven't read that section but maybe there is something in there procedure-wise?
. Cheers, Greg
Post #547558 18th Mar 2020 10:54pm
Southeast
No might have a look
Post #547559 18th Mar 2020 11:01pm
GraemeS
kit includes....
uk made aftermarket belt tensioner.
could still be the crankshaft pulley though.
Post #547571 19th Mar 2020 7:59am
Baltic Blue
What was the problem that Craig highlighted years ago that causes the edge of the belt to rub , chaff and fail?
I will add it to this post if I can find it. Rolling with laughter Plenty of spare time to look for it now I am in over 70 forced lockdown.
Post #547572 19th Mar 2020 8:20am
Southeast
That would be a super help thanks
Post #547576 19th Mar 2020 9:39am
GraemeS
The common problem is due to a worn tensioner and yours has since been replaced.
Post #547578 19th Mar 2020 10:26am
Southeast
Exactly just thought someone might have found a different issue . hopefully !!
Post #547579 19th Mar 2020 10:31am
