![]() | Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs? |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hi all
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I haven't tried those but you can't fit any with a fan or heatsink on the back.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Quote from listing:
I have some led bulbs with the rear rather bulky fans fitted to my secondary main beam headlights. Granted they are difficult to fit but not impossible, it means taking the headlight off the car to fit them. The light output is very impressive, had them on a couple of years now so probably due to fail soon. Would definitely fit similar again. |
Did you modify the metal clip that holds the bulb in to the housing? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Ive used the type with the aluminium webbed rope cooling strips on many different applications...
Have you got a link to anything, Craig?
Didn't need to modify it, but I did take it off and repositioned it, I think I moved it through 180 degrees from memory. As I said difficult to fit but not impossible. |
These are the type i have used... Not from this seller, but you get the idea sir... ![]() https://www.ebay.co.uk/itm/6B00-White-H7-6...SwQY9eFIqP |
Thank you Craig.
Often the plastic part of the LED bulb, the bit that takes the shape of the original bulb securing/locating ring turns 45/90 degrees and slides off! This allows you to fit the holder, then fit the bulb with a quarter/half turn to lock it in place sir... 👍 |
Thanks for that Craig. Very thick of me not to notice that the plastic bit comes off. Still not sure they'll fit though. |
Hi all
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Any body seen jim4244, said he was going to report back on these led bulbs hope they didnt fail on him and he missed that corner or the car broke down (other options are available). |
