Home > Maintenance & Mods (L322) > 0w-30 vs 5w-30 Oil - 4.4 TDV8
Page 1 of 4 1234>
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
I like to carry around a spare litre of oil in the car, so just went on to Opie Oils, who have a black Friday sale, to stock up. However, when I put in my reg number they list out 5w-30 oils. But on the oil cap in the engine bay it clearly says 0w-30?
So which should I go for? 0w will be thinner at cold temps than 5w, will it make that much difference? I'm leaning towards following LR guidelines and going for 0w, but interested to hear other views.
Mine is a 2012 TDV8
Post #535388 25th Nov 2019 11:53am
Baltic Blue
The drivers handbook states 5-30 C1 spec. oil and I have always used Shell Helix Ultra 5-30 AF-L from Opie with no problems.
Post #535394 25th Nov 2019 12:50pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I've wondered what I should get for a top up - I've not needed to top it up yet, but I don't like the idea of being caught on the hop. Any specific recommendations for a 4.4 tdv8?
My previous BMW apparently needed a particular formulation (not that it did it much good as it still suffered tappet failure). Is the RR the same, or will any old decent oil of the correct spec do? 2010 4.4 TDV8 Vogue SE
Post #535472 26th Nov 2019 8:44am
DrRob
Use the Shell Helix spec as above Thumbs Up
Opie oils sell it.
I have a small 1L in the boot of some I got from Advanced Factors a while back. Not Shell but in spec and there for non planned top ups. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535473 26th Nov 2019 8:48am
DrRob
ADV914 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535477 26th Nov 2019 8:50am
DrRob
https://www.advancedfactors.co.uk/service-...-168-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535478 26th Nov 2019 8:50am
Always used shell helix aF-L in mine with no problems. There is nothing that can't be fixed with a hammer😜😜
Post #535545 26th Nov 2019 7:26pm
Oil type on ALL 4.4TDV8's & 3.0TDV6 is absolutely critical people... The oil needs to have all the correct letters & numbers after it! Its imperative Exclamation
Post #535588 27th Nov 2019 12:21am
kooky_guy
Thanks Craig,
That's what I was worried about. So do the oils linked above have the correct letters and numbers?
Or can you suggest something?
[/quote] 2010 4.4 TDV8 Vogue SE
Post #535592 27th Nov 2019 8:31am
Baltic Blue
She’ll helix AF -L as per the picture definitely does meet the spec, but you need to be VERY CAREFUL when buying, because they sell so many similar looking containers with different specifications, but ONLY AF -L will do.
Craig is spot on in saying it is critical.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #535594 27th Nov 2019 9:50am
Fox889
Keep an eye on Opie's website, hopefully Opie will have a 'special' on black Friday, 20% would be nice! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #535598 27th Nov 2019 10:53am
kooky_guy wrote:
Thanks Craig,
[/quote]
It states the exact oil type in everyone’s service books... For clarity, I suggest you take a pic of that page and make 100% sure when purchasing, that the oil matches perfectly what it asked you in your book sir...👍
I ordered a large amount of oil in when ECP has a deal on... The manager at our local branch sent us FOUR!!! shipments assuring me “this one is right” apologising each time!!! Two of them were incorrect Shell Helix! Before they found the correct one at twice the price!
Post #535599 27th Nov 2019 11:04am
M@r]{
Here you go, photo from my Owners Handbook. I am wondering, what is the AF-L you refer to?
Post #535601 27th Nov 2019 11:44am
rjff
From Shell's website, spec for said oil for the 4.4
https://www.shell.com/motorist/oils-lubric...5w-30.html
See the WSS spec.
(Even they get the picture wrong, AR-L) Cheers
Richard
(there are no such things as an ordinary FullFat, an ordinary cat or too many tools)
2011 TDV8 Vogue Santorini Black
Gap IIDBT
Post #535603 27th Nov 2019 11:54am
DrRob
All the Advanced Factors oils specified for the 4.4 TDV8 with DPF meet WSS-M2C934-B.
All are coded ADV914 on their site for simplicity.
I have 1L of one in the car as a just in case.
Shell Helix meet same WSS-M2C924-B spec if you look on Opie Oils site.
Currently 15% voucher too Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #535605 27th Nov 2019 12:09pm
Page 1 of 4 1234>
