Home > Maintenance & Mods (L322) > 0w-30 vs 5w-30 Oil - 4.4 TDV8
Page 3 of 4 <1234>
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Well I'm still a bit confused. It really wasn't this difficult with my P38!
I suppose I need to confirm whether mine has a dpf or not. I assumed it had, but recent threads have made me question it. 2010 4.4 TDV8 Vogue SE
Post #535653 27th Nov 2019 5:17pm
Baltic Blue
https://www.fullfatrr.com/forum/topic52086.html
This post by Bradders was definitely the cheapest deal ever, so it might be worth checking their website on Black Friday.
Post #535654 27th Nov 2019 5:20pm
rjff
rjff wrote:
I've asked Shell about the photo on their website being of a AR-L but the spec being AF-L. Will let you know if I get a reply.
That was asked at 1128 this morning and this reply arrived at 1612
Thank you for bringing this up to us. It does indeed appear to be a mistake in the photo--the product should be a Shell Helix Ultra Professional AF-L 5W-30 which meets the Ford WSS-M2C934-B specification as indicated in the description. I will feedback this to the relevant team for the corresponding changes to be made.
Thank you again for your feedback.
Quick reply, as they say GO WELL WITH SHELL Razz OK,sorry Rolling Eyes Cheers
Richard
Gap IIDBT
Post #535667 27th Nov 2019 7:00pm
Yes yours does sir... Every 4.4TDV8 has a DPF... The confusion i believe is that some 2010 3.6TDV8 came with and some without apparently??? BUT 100% all 4.4TDV8's have DPF's Thumbs Up
Post #535672 27th Nov 2019 7:42pm
[quote="M@r]. Gearbox Flush: £280 all in. Additional £150 for trans and diff oil change.[/quote]
Shocked Shocked Shocked That was a mistake on their side im guessing Shocked Shocked Shocked
Post #535674 27th Nov 2019 8:04pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
M@r]{ wrote:
No probs putting them up here in public.
Mines a 2012 TDV8. Gearbox Flush: £280 all in. Additional £150 for trans and diff oil change.
I thought that the 8 speed could not be flushed? on reading on here and other places.
Was that wrong?
Thanks
Post #535781 28th Nov 2019 9:18pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
That’s definitely wrong, I’ve talked to a few places that do it
Post #535782 28th Nov 2019 9:38pm
neilly
Thanks for the heads up, appears they can now do it, must have read an older post.
Just found it, great news. I will have to give them a call.
https://blog.jgs4x4.co.uk/2019/05/28/gearb...at-jgs4x4/
Thanks
Post #535783 28th Nov 2019 9:45pm
Yes they can be flushed but be careful, there is a thermostat in the system that does not allow “standard flushing” so make sure the company offering the service knows what they are doing sir...
Oh and ZF suggest flushing is not good for the gearbox so read up first and make your own mind up sir 👍
Post #535794 28th Nov 2019 10:39pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Just a twist to this tale, Australian Spec L322 4.4TdV8's were not equipped with a DPF ! Another reason along with the fuel economy and performance makes them very desirable down under. Apparently the first batch of L405's weren't equipped with a DPF either. This is probably due to the late take up of the Euro Emissions legislation here.
Laurie
Post #535818 29th Nov 2019 1:12am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
M@r]{ wrote:
Here you go, photo from my Owners Handbook. I am wondering, what is the AF-L you refer to?
I think this spec for non dpf engines is wrong.
There is no 5w30 oil for that spec.
It is for heavy duty diesel trucks and only 10w40 or 15w40 available for that spec. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #536668 7th Dec 2019 6:18pm
The 913b spec is the same as for my disco and the old 3.6. Shell do HX7 in a 5w30 which meets 913b, but tbh It’s a mute point as Uk cars have a dpf so need 934b, it is also “synthetic technology” oil not fully synth....
 There is nothing that can't be fixed with a hammer😜😜
Post #536845 9th Dec 2019 10:15pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Used the Millers C1 in mine for last 30k miles , big fan of Millers personally , just my twopennies worth .
Post #537161 12th Dec 2019 11:00am
Talkwrench
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Can anybody vouch for this?
It seems to meet all the required standards and is considerably cheaper than most at only £18 for 5 litres!!!!
https://www.advancedfactors.co.uk/adv914-0...5686-p.asp Cheers, Andy
2011 Autobiography TDV8
1996 Mazda RX7 Type RZ
Post #537980 20th Dec 2019 12:03pm
DrRob
Paul Redding runs Advanced Factors and would not stock Censored oils. I have a small Grenville in my boot box Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538004 20th Dec 2019 2:42pm
Page 3 of 4 <1234>
