Home > Technical (L322) > porous block. Coolant leak. As much help as possible please.
Page 4 of 4 <1234
dingg1
I had a tiny leak as you have and had a major journey to Portugal where I now live, I didn't fancy something letting go in a bigger way on the journey so bunged in some k seal, I kept an eye on all temps and there was no sign of anything getting hotter than usual, that was a year ago.
I have used the car in ambient temps up to 36 deg C. It hasn't missed a beat and has only required 300ml of coolant adding in 12 months and 15000km.
I'm a convert, it did the job for me.
Very Happy
Post #531803 22nd Oct 2019 3:41pm
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
INTERETSING.. Thanks
its certainly something to consider. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #531807 22nd Oct 2019 3:53pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
+1 for K Seal.
Dazza, I reckon you may have just had an air lock.
Keep an eye on the level as previously mentioned. Use the UV bottle & if all ok or minimal loss. Add K seal. Thumbs Up
Post #531809 22nd Oct 2019 4:21pm
dazza1983
and the k seal will be all good for my car? I can just carry on as if it never happened lol?
Interesting to see people have such split views? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531837 22nd Oct 2019 7:38pm
dingg1
Yes
Split views but take note of the people that have used it without issue.
Plenty will say its snake oil but they're the same people who haven't used it.
I used it as described and have encountered no issues whatsoever. Very Happy
Post #531843 22nd Oct 2019 8:34pm
dingg1
Yes
Post #531844 22nd Oct 2019 8:35pm
dingg1
Yes
Post #531845 22nd Oct 2019 8:35pm
dingg1
Yes
Post #531846 22nd Oct 2019 8:35pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I used a similar product on my 4.6 P38. You have to follow the instructions to the letter. In my case I had to flush out all the coolant from the system before adding the product (can’t remember it’s exact name). I never had any issues with it, kept the car for another 8 years and it was close to 150,000 miles when I finally sold it. So a good 60,000 miles covered by me. However, before taking the plunge and buying the K Seal I would be inclined to follow the advice already given and use your RR and keep an eye on the coolant level at least that way you’ll know for sure if there is any coolant loss or whether it was an air lock that caused the original issue.
Post #531953 24th Oct 2019 6:00am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
ive had several vehicles with crack blocks and two with cracked valve walls and one with a porus head , the cracked block cars smoked like mad , the crack valve wall cars pressurised the coolant system and coolant needed topping up but could take a few weeks , the porus head one refused to start when cold so I think if you had any of those there would be symptoms pal
Post #532031 24th Oct 2019 6:46pm
Page 4 of 4 <1234
