Home > Technical (L322) > porous block. Coolant leak. As much help as possible please.
Page 2 of 4 <1234>
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Chances that the water is being lost through evaporation in the combustion process had a diesel Passat that did exactly that no mayo signs but when it got hot water wasn’t in the combustion chamber
Post #531691 21st Oct 2019 4:23pm
Even really bad cooks can't burn water (but I know what you mean...) .
Post #531700 21st Oct 2019 5:30pm
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Sorry chaps. I don’t understand that last 2 posts??
Where would the water be getting burnt? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #531701 21st Oct 2019 5:34pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Interesting Read Rolling Eyes .
Question a porous block though, surely you would have an issue with the engine components before the block. No signs of snail trails around the engine showing possible leaks.
How long have you been topping up the coolant system, how often & what quantity?.
Any signs of water leaks, smell of antifreeze when hot etc.
Has the engine ever over heated?.
Any history of coolant issues, work being carried out previously by previous owners etc.
White smoke being omitted from the exhaust?.
More than likely the coolant is entering the cylinders from another means rather than a porous block.
We await the update (bet they suggest an exchange engine) Rolling with laughter
Post #531702 21st Oct 2019 5:57pm
Gsxr1250dave
Have you put fluro dye in the coolant yet ?
Post #531704 21st Oct 2019 6:09pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Coolant may be getting into the combustion chamber via head gasket and being 'burnt' off (converted to steam).
Usually the coolant system would get pressurised by the combustion gases if there's a leak into the combustion chamber which leads to bubbles and oil in the system (mayonnaise). There's a simple check for gases in the coolant with colour changing dye which snifs the gases in the expansion tank (called a 'block tester') or it can be checked for CO2 content with an exhaust gas analyser.
It doesn't always happen though, coolant can leak into the combustion chamber without causing a reverse effect to the coolant system. A Leak Down test may help although pressures would be less than happens during combustion so may not show issues. The other check would be inspection of the combustion chambers for effects of the 'steam' cleaning caused by a coolant leak.
A bad leak would be obvious by steam in the exhaust when running.
What sort of loss are we talking here?
'Undetectable' smaller leaks would be stuff like the heater matrix although bad leaks there would lead to steaming up of the cabin when running.
Post #531705 21st Oct 2019 6:13pm
dazza1983
Only topped it up twice in past 2 weeks. Once was the 1st time I was aware of the problem and put 1 litre in. 5 days later 1/2 litre.
No signs of water leaks. I have noticed a few time’s a hot smell after getting out of the car.
not that I am aware of.
Only 1 previous owner. No history of any coolant work at all.
More than likely the coolant is entering the cylinders from another means rather than a porous block. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531706 21st Oct 2019 6:17pm
I hate to ask but... you are sure you put the new coolant in the hole it is supposed to go in. Whistle
Post #531708 21st Oct 2019 6:47pm
dazza1983
Yes buddy. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531709 21st Oct 2019 6:51pm
dazza1983
Would it be possible to get a list of places that coolant could go?
Or would it be too big or too hard to give every possibility?[/img] Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531710 21st Oct 2019 6:55pm
dazza1983
Should I try this??? And if so is one bottle enough?
UV Dye & UV Torch Kit Leak Detection Fluid For Car Cooling Antifreeze System RLD2 https://www.amazon.co.uk/dp/B00TU8VCB4/ref...RDbHMBW7CD Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531714 21st Oct 2019 7:17pm
dingg1
Get a large dose of k seal in there
Run it, say nought to anyone, and see how it goes.
If it's a tiny leak flashing to steam that would seal it.
That's what I'd try before launching a lot of money at it.
Post #531716 21st Oct 2019 7:23pm
GGDR
compression test?
. Cheers, Greg
Post #531730 21st Oct 2019 8:57pm
dazza1983
will a compression test help much? Also are they easy to do on a diesel v8? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #531731 21st Oct 2019 9:12pm
GGDR
not sure on a diesel actually.
but you'll know if your head gaskets are ok.
less work to try dingg1's suggestion ^^
just thinking of the basics....
. Cheers, Greg
Post #531735 21st Oct 2019 9:24pm
Page 2 of 4 <1234>
