![]() | Home > Maintenance & Mods (L322) > L322 Side Steps question |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Where do they rust/crack out of interest? I have them on mine so would like to check if mine are ok. Cheers |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
my left one (not shown) has a crack in the trim where the previous owner touched something.
Thanks for that, I’ll take a closer look at mine. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
theres a good chance that the chinese copies will be he same as LR genuine...
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
I bought mine from Direct 4X4 (Derby) in 2015 @ about £250, came with all fixings and front mud flaps.
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
I put brand new aftermarket ones on mine 18 months, ago, last month drivers side dropped and upon investigation found the brackets that have keyhole shaped holes had corroded away completely hence leaving nothing to attach too, I had black waxoyled mine on day on of fitting too!
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
My genuine ones rusted away so badly that they collapsed causing an injury, so I wouldn't put too much store in them.
Guys,
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
My 2007 VSE passenger fixed side step snapped due to rust , i believe they were 7 years old at the time. On removing both steps to replace , lots of rust was found in them. 2015 4.4 AB
Thanks everyone especially Strider and Stan.
Thanks Range Rover L322 |
As per Strider's recommendation I ordered side steps from Direct4x4 as they looked exactly what I wanted.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I put copies on when those on my TD6 rusted through. I left the OE mudflaps on though, managed to get copy step to fit up to them ok.
Wow. Wasn't expecting this level of degradation - this is a bracket for the mudflap on the other side. My chassis and internal RR structure is pristine but if you've got sidesteps this is worth investigating.
