Home > Maintenance & Mods (L322) > L322 Side Steps question
Page 2 of 3 <123>
GGDR
Range Rover L322 quite a shine you have there! Thumbs Up
Bit of a side question, how do you remove the panel at the bottom of the wing?
. Cheers, Greg
Post #529480 29th Sep 2019 3:05pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Our cars should have been made to lower upon demand much further than they do, this would have negated the need for unsightly fixed sidesteps or indeed expensive complex deployable ones, poor forward thinking by Land Rover. Confused 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #529481 29th Sep 2019 3:06pm
Range Rover L322
This chap is really helpful... to remove that panel pull out the bottom then there's an 8mm hex head self tapping screw pointing upwards at the front side. Hard to get to, this video explains all.
Post #529510 29th Sep 2019 8:13pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
took my side steps off yesterday as they were collapsing, four of the small 10mm bolts broke off so if I want to fit new steps I have to find a way of drilling out holes and retapping. No space due to air suspension tank.
Has anyone managed to drill out rusted bolts ?
Also how do the sill protectors come off, do I just take out plastic clips at bottom and pull off. Thought I would check all areas for rust just in case.
2012 TDV8
Rog
Post #529561 30th Sep 2019 12:20pm
DrRob
"Also how do the sill protectors come off, do I just take out plastic clips at bottom and pull off. Thought I would check all areas for rust just in case."
Next job on my list.... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #529562 30th Sep 2019 12:23pm
Range Rover L322
Rog21. One of my 13mm bolts sheared. I don't have welding gear at home so I took it to a local welder who welded a nut onto the stub and got it out. That should work for you as it doesn't require drill space or re-tapping.
Until then WD40 it every day!...
I put new 10mm nuts on all 8 - getting them in past the air tank was not a problem.
Post #529618 30th Sep 2019 8:51pm
Rog21
If only it was that easy. The 13mm broke leaving no exposed thread, that's fine as I can drill out.
The 10mm also left no thread exposed so nothing to weld to. I am looking at investing in a 90 degree drill attachment to see if I can drill them out. I may have to remove air tank (after releasing pressure) to get to it.
Roger
Post #529679 1st Oct 2019 12:28pm
Nick591
I had to drill out and retap the two front 10mm bolts on each side. I used a right angle drill. On the air tank side I reasoned that if the holes weren't exactly square to the chassis a) it wouldn't affect the mechanical strength or function of the fixing, and b) it would make retapping the thread a lot easier. So it proved. My biggest problem was blunt drill bits. Must get a drill sharpener!
I think my side steps were fitted to the car when new and the nearside one bent down at the rear when my son got in. Turned out both sides were riddled with rust. Replaced with aftermarket 'oem' ones - a discounted offer from Dan at Duckworths. Spray coated both new ones with waxoyl underneath before fitting and used stainless 10mm bolts. Kept original front mudflaps. All good. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #529908 2nd Oct 2019 10:59pm
Rapiscan
Unless you need steps to get in n out, why bother with em? They are ugly dirt collectors inho. Despite people's best efforts they WILL corrode, they all seem to be made of cheap mild steel, dunno if deployable ones are better regarding corrosion? Considering the price I'd hope so, I've no regrets about scrapping my old steps, Im fortunate i can get in and out without dragging the seat bolster excessively. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #529933 3rd Oct 2019 11:49am
Tim
Do Sport side steps fit?
Post #628452 12th Apr 2022 3:21pm
mjdronfield
I wouldn’t think so. Platform of the car is different.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #628467 12th Apr 2022 5:21pm
Tim
Ta
Post #628468 12th Apr 2022 5:46pm
Tim
Mounting points are completely different - I checked with my mate's Disco 3, which (I am fairly sure) shares the same platform
Post #628535 13th Apr 2022 10:00am
garyRR
Yes aftermarket are basically the same however, when I got a pair on my old RR, there were a few quality check issues from the factory - one of the side steps was warped and hung slightly low. And, the bolt holes didn't exactly like up and were around 3mm off in places - not much but enough of a pain to have had to re-drill the holes larger in order for the bolts to fit the chassis.
So, if you get a pair and no quality issues, I'd say there's not really any difference to the genuine ones which are fitted on my current RR. The receipt from LR main dealer says they cost £1,100 for both side steps, mudflaps, fitting and VAT... but that was many moons ago so, I'd imagine more like £1,300 today. 2015 Range Rover Autobiography 4.4 SDV8
Post #628718 15th Apr 2022 12:52pm
jackie-o
Netherlands
@Range Rover L322, do you know if its possible to fit your after market versions into the original front mud flaps?
//j RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #629066 19th Apr 2022 11:20am
Page 2 of 3 <123>
